> 1MZ-FE into my MR2, Building a 3SGTE these days.
post Dec 15, 2010 - 1:03 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
I don't own a 6GC anymore, but I am attached to this place, so you guys are stuck with me.
The V6 is a swap that MR2 gurus are doing these days. I suppose when you get a bunch of guys in their 30's and 40's with handfuls of disposable income, this is the result. I know there have been a few V6 swaps into the 6GC, and since the MR2 shares a bit with the Celica, I am making this thread in the hopes that someone on here will find it and get some of the information that they need.
Why I chose the 1mz over a 3sgte
Simple, really. I see the MR2 as a cheap exotic, why not make it sound like one? Power is the same if not a bit higher than the 3s, but it has torque the moment you put your foot down. Good fuel economy, reliable, yada yada yada. It actually gives you more room in the engine bay than the 3S, too.
Why the 1MZ over other V6 options?
Weight, cost, and availability. The 1MZ has an aluminum block. It actually weighs less than the 3sgte. The 3VZ has a cast iron block, and people opt for those if going with a turbo, but I'm not. I have my WRX for turbo shenanigans - this car is meant for reliable enjoyment. The 2GRFE would be incredible - 275whp stock... Only problem is finding one, and cheap. Most places that have them are selling them at more than what my swap will cost me... plus I would need to upgrade to the E153 transmission, turbo axles, hubs, brakes, etc. Just pile on the parts. Seems like a more suiting swap for someone who is starting out with a turbo MR2.
I picked my 1MZ up from another NASIOC and MR2OC board member who decided to go for a Honda V6 swap instead. He pulled this motor out of a 94 Lexus ES300 with 90k miles on it. It ran great, just got t-boned. No sludge, either. Owned by an old couple, this car was just in to the dealership for it's 90K service. If it weren't for the fact that timing belts are cheap, I might just leave this one on there. The guy I bought it from had already gone through the trouble of sourcing a new passenger side motor mount from 4v6 on the MR2 boards to make the swap drop straight in. The ES300 never came in manual transmission, and because of the lack of an automatic transmission in my car, this will throw a CEL. I am still trying to think of ways around this, but it'll probably end up with some sort of EMS.
So I started my list of what I still need to source... after compiling the list I thought to myself, I probably should have thought about this more.
- Custom headers Brad Bedell makes a set for $300, but requires a bit of modification to the runners to not hit the oil filter.
- Flywheel Need to get a V6 flywheel for a Solara. Decided on a Fidanza unit. Why not, right? $310
- Clutch The V6 flywheel is the same diameter as a mr2 turbo flywheel, but my clutch isn't. To maximize the surface area and avoid slipping I need to get a turbo clutch kit with a custom 20 spline disk to mount my S54 to the 1MZ. South Bend Clutch can do a kevlar clutch kit with 20 spline disk for $300.
- Tachometer The v6 sends a different signal than the 5s, so you need to source a v6 tach board from a camry for this. Drops right in to the MR2 cluster, but I am having my stock tach modified and recalibrated. $50
- Wiring I know this is going to be a nightmare to wire, so that is a headache I'm passing to someone else. Dr_tweak wants $630 to do it.... WTF happened to the $300-$400 conversions? Luckily there is a mr2 board member who does the work for $430.
- Exhaust work I have headers outlined above, and already have a Greddy SP muffler, so my exhaust shop needs to build a y-pipe to connect the two. Speculated cost with my discount (I refer A LOT of business to them) is around $200.
- Misc. crap Timing belt, gaskets, fluids, etc. I am also bundling kirkosaurus poly mount inserts under this category. $300
I've got about $1700 left to spend on this trip. Already spent $750 on the engine and everything I'll need from the donor car. I've set a deadline of February 28th to have it completely finished. If it wasn't for this Christmas BS (Now I know why adults hate this time of year) I would be well on my way. No problem.
I'm writing all of this out from my cell phone, so its all a bit jumbled and unformatted, but I've been meaning to post this stuff for a while. When I get to my computer I'll organize it and get some real info going. Until then, gaze upon awesomeness.
Okay, I'm home from work... and now I can reformat.....
Alright, now that is over with... I pulled the harness off of the motor last night.... And it's substantially larger than my 5S harness. This thing almost spans the length of my car! I'm not going to work on it tonight, but tomorrow I am going to go through and label the harness, and try and source some injector clips - the plastic was pretty brittle on mine and I snapped all but one of them. kindasad.gif
The guy I bought it from partially unwrapped the harness, so it looks nastier than it really is, but this harness has to weigh at least 30lbs. I'd like to see how much it'll weigh after I get it back.
This post has been edited by 95CelicaST: Oct 2, 2017 - 3:46 PM
**** Photobucket
- 95CelicaST   1MZ-FE into my MR2   Dec 15, 2010 - 1:03 PM
- - mak5603   This is AWESOME! I can't wait to see this ...   Dec 15, 2010 - 1:59 PM
- - 95CelicaST   Reformatted and added/elaborated on a few things.   Dec 15, 2010 - 8:33 PM
- - SupraKid   Nice! Should be pretty beastly when its done...   Dec 15, 2010 - 8:46 PM
- - Johnnyny   Badass!   Dec 15, 2010 - 8:57 PM
- - Ted95   sweet stuff man cant wait to see more!   Dec 16, 2010 - 12:01 AM
- - epocsirhc   Good stuff! I can't wait to hear what it s...   Dec 16, 2010 - 12:26 AM
- - 95CelicaST   This version of the 1MZ is rated at 190 hp and 193...   Dec 16, 2010 - 11:22 AM
- - SwissFerdi   Best of luck, Spongebob.   Dec 16, 2010 - 3:09 PM
- - 95CelicaST   Went through and labeled the wiring harness last n...   Dec 18, 2010 - 1:14 PM
- - blu94gt   I've wanted to do a v-6 MR2 for a looong time....   Dec 18, 2010 - 4:02 PM
- - njccmd2002   off topic should be separated into categories, thi...   Dec 18, 2010 - 4:12 PM
- - 95CelicaST   Thanks guys. I'm going to try to make it as pa...   Dec 18, 2010 - 6:14 PM
- - Random_Stranger   ^^ Really looking forward to this man. Just curi...   Dec 19, 2010 - 12:03 PM
- - 95CelicaST   From what I saw, prices were around $2,000 fo...   Dec 19, 2010 - 4:40 PM
|- - Random_Stranger   QUOTE (95CelicaST @ Dec 19, 2010 - 1...   Dec 19, 2010 - 7:38 PM
- - 95CelicaST   No it's not bad, it's just the wiring and ...   Dec 20, 2010 - 2:07 PM
|- - Random_Stranger   QUOTE (95CelicaST @ Dec 20, 2010 - 11...   Dec 20, 2010 - 9:23 PM
- - 95CelicaST   I have time and money right now, and I'm going...   Dec 20, 2010 - 10:25 PM
- - HectortheRican   I can't wait to start following this build...   Dec 21, 2010 - 3:58 AM
- - 95CelicaST   5SFE harness showed up this morning... I went to f...   Dec 24, 2010 - 9:59 PM
- - 95CelicaST   Updating without any pictures I ordered the clut...   Dec 30, 2010 - 9:22 PM
- - 95CelicaST   Pictures! nom nom nom Oil filter relocation k...   Dec 31, 2010 - 9:48 PM
- - 95CelicaST   Sitting in my living room watching horrible movies...   Jan 1, 2011 - 11:56 PM
- - DEATH   Nice project bro! Should be beastly when mated...   Jan 2, 2011 - 1:21 AM
- - richee3   RE: 1MZ-FE into my MR2   Jan 2, 2011 - 1:40 AM
- - 95CelicaST   stock for stock this is faster than a mr2 turbo. P...   Jan 2, 2011 - 1:54 AM
|- - DEATH   QUOTE (95CelicaST @ Jan 2, 2011 - 12...   Jan 3, 2011 - 7:40 PM
- - njccmd2002   nice...   Jan 2, 2011 - 4:05 AM
- - Johnnyny   esto es SEXO!   Jan 2, 2011 - 1:31 PM
- - Bitter   I would HIGHLY suggest getting those headers coate...   Jan 2, 2011 - 1:34 PM
- - 95CelicaST   No way to do anything with the paint - the car was...   Jan 2, 2011 - 1:56 PM
- - 95CelicaST   Success. The "generic" Toyota filter ...   Jan 2, 2011 - 8:11 PM
- - Bitter   nah, get them coated. trust me. at idle that V6 i...   Jan 2, 2011 - 9:59 PM
- - 95CelicaST   .... Alright, I'll trust you on this. Haha. Th...   Jan 3, 2011 - 2:28 PM
|- - epocsirhc   QUOTE (95CelicaST @ Jan 3, 2011 - 3...   Jan 3, 2011 - 11:55 PM
|- - Bitter   QUOTE (95CelicaST @ Jan 3, 2011 - 2...   Jan 5, 2011 - 12:02 AM
- - Keiri   This build is really awe-inspiring. Definitely kee...   Jan 3, 2011 - 8:54 PM
- - 95CelicaST   At this rate I'll have everything else and be ...   Jan 4, 2011 - 1:18 AM
- - njccmd2002   oK Call me an idiot, why is that header pointing t...   Jan 4, 2011 - 2:40 AM
- - 95CelicaST   Idiot that's the rear bank - it's pointi...   Jan 4, 2011 - 2:50 AM
|- - HectortheRican   QUOTE (95CelicaST @ Jan 4, 2011 - 1...   Jan 4, 2011 - 9:16 AM
- - 95CelicaST   Well my flywheel has been sitting in a Fedex build...   Jan 5, 2011 - 12:28 AM
- - Ted95   wow looking good dude, good work   Jan 6, 2011 - 4:00 PM
- - 95CelicaST   FedEx says it'll be here tomorrow, but it...   Jan 6, 2011 - 4:04 PM
- - presure2   looks good so far man! keep it up!   Jan 6, 2011 - 6:05 PM
- - 95CelicaST   Thanks Manny. Performance Coatings isn't ope...   Jan 6, 2011 - 6:49 PM
- - 95CelicaST   Well I'm eating my words today. I dropped my h...   Jan 7, 2011 - 9:38 PM
- - Johnnyny   sometimes when u ship via ups it might end up in f...   Jan 7, 2011 - 10:39 PM
- - Bitter   Oh, what kind of gun did you get?   Jan 9, 2011 - 11:03 AM
- - 95CelicaST   I actually bought two. I initially bought a cheap ...   Jan 9, 2011 - 11:48 AM
- - Bitter   Yes, for you...get a pipe and breaker bar and some...   Jan 9, 2011 - 1:09 PM
- - 95CelicaST   Yeah that's my plan for this afternoon is to r...   Jan 9, 2011 - 1:47 PM
- - Bitter   what size/airflow is your compressor? the one at w...   Jan 9, 2011 - 6:43 PM
- - 95CelicaST   It's just an inexpensive Husky 6 gallon compre...   Jan 9, 2011 - 8:41 PM
- - 95CelicaST   Huzzah!   Jan 10, 2011 - 12:15 PM
- - 95CelicaST   Double post ftmfl   Jan 10, 2011 - 12:15 PM
- - HectortheRican   Crank pulley: terminated! High five!   Jan 10, 2011 - 12:48 PM
- - 95CelicaST   Crank pulley: 0 6ft breaker bar: 1 yessssssss   Jan 10, 2011 - 3:21 PM
- - Bitter   Congrats! one thing I've noticed on more t...   Jan 10, 2011 - 8:19 PM
- - 808celica   Interdynamics gun???   Jan 11, 2011 - 2:33 AM
- - 95CelicaST   Ingersoll-Rand.   Jan 11, 2011 - 3:16 AM
- - 95CelicaST   Got my headers back. Nom nom nom. Flywheel bolts w...   Jan 13, 2011 - 9:56 PM
- - njccmd2002   call me an idiot but why your header only has 3 pi...   Jan 13, 2011 - 10:29 PM
- - 95CelicaST   My spreadsheet of crap left to buy is getting smal...   Jan 14, 2011 - 2:01 AM
|- - Bitter   QUOTE (95CelicaST @ Jan 14, 2011 - 3...   Jan 16, 2011 - 8:53 PM
- - HectortheRican   Ahh, those headers are sexy.   Jan 14, 2011 - 6:31 AM
- - 95CelicaST   Update for this weekend: The summary of this week...   Jan 16, 2011 - 5:34 PM
- - SwissFerdi   THIS build IS SPAAARTAAAAAAAAAAAAAAAAA!   Jan 16, 2011 - 6:07 PM
- - 95CelicaST   Thank god it won't be my first time doing it. ...   Jan 17, 2011 - 2:37 AM
- - stephen_lee   woot wooot! with my tax return comes.... megas...   Jan 17, 2011 - 2:20 PM
- - 95CelicaST   Drawing closer now... My clutch showed up at my h...   Jan 20, 2011 - 10:01 PM
- - HectortheRican   I say that you should paint the intake manifold a ...   Jan 20, 2011 - 10:17 PM
- - richee3   I vote paint it. Are you leaving the engine bay re...   Jan 20, 2011 - 10:17 PM
- - 95CelicaST   No the bay isn't being painted... why would I ...   Jan 20, 2011 - 10:42 PM
- - JuMPiiN   Looks nice ! keep it like it is if your cover ...   Jan 20, 2011 - 10:46 PM
- - 95CelicaST   It'll be the motor that should have gone in th...   Jan 21, 2011 - 1:18 AM
- - richee3   Seems like half the motor swaps I see have engine ...   Jan 21, 2011 - 1:32 AM
|- - HectortheRican   QUOTE (richee3 @ Jan 21, 2011 - 12:3...   Jan 21, 2011 - 1:47 AM
- - 95CelicaST   1mzfe is 346lbs 5sfe is 385lbs 3sgte is 463lbs ...   Jan 21, 2011 - 8:28 AM
- - HectortheRican   Gaw, that's insane how much incredibly lighter...   Jan 21, 2011 - 9:00 AM
- - richee3   So you're actually going to lose some weight? ...   Jan 21, 2011 - 12:18 PM
- - Stambo   super charge it   Jan 21, 2011 - 7:39 PM
- - 95CelicaST   Send me 3k for the TRD unit. Better yet, find on...   Jan 21, 2011 - 9:04 PM
- - Bitter   Awesome. Leave it NA and build a nice ITB setup......   Jan 22, 2011 - 8:29 AM
- - spolski07   you should drop a LS1 into it instead... cause t...   Jan 22, 2011 - 9:11 AM
- - 95CelicaST   Today was a bit productive. I reinstalled the upp...   Jan 24, 2011 - 12:17 AM
- - 95CelicaST   Pictures! Lower intake manifold with the fuel...   Jan 24, 2011 - 11:56 PM
- - njccmd2002   nom, nom, nom..... In a celica nom nom nom   Jan 25, 2011 - 2:50 AM
- - njccmd2002   sorry, what tranny are u using, will it bolt to th...   Jan 25, 2011 - 2:58 AM
- - SupraKid   QUOTE (njccmd2002 @ Jan 24, 2011 - 11...   Jan 25, 2011 - 4:56 AM
|- - njccmd2002   QUOTE (SupraKid @ Jan 25, 2011 - 3:5...   Jan 25, 2011 - 6:20 AM
- - Ted95   dude this is such a sick build, love it!   Jan 25, 2011 - 1:37 PM
- - 95CelicaST   Beginning of re-routing vacuum lines on the intake...   Jan 25, 2011 - 9:54 PM
|- - spolski07   QUOTE (95CelicaST @ Jan 25, 2011 - 8...   Feb 1, 2011 - 7:49 PM
- - Bitter   yank those heads and port them! ok ok maybe no...   Jan 25, 2011 - 10:38 PM
- - 95CelicaST   I would, but porting costs a nice chunk of change,...   Jan 26, 2011 - 6:59 PM
- - tjblacrosse   drooool.... looks good man! I got a chubby fro...   Jan 28, 2011 - 10:25 AM
- - 95CelicaST   Just a quick update: Replaced the oil pan gaskets...   Feb 1, 2011 - 11:23 AM
- - njccmd2002   hey, do you have a pic of the passengers side moun...   Feb 1, 2011 - 7:40 PM
7 Pages V   1 2 3 > »
105 User(s) are reading this topic (105 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: August 26th, 2026 - 10:06 PM
