> Boosting Problems, I Really need help on this one. I cant work it out
post Dec 17, 2010 - 3:35 AM
ST-204R
Joined May 3, '10
From Orange
Gday all, Im having a problem with may 3SGTE boosting. To give everyone an idea of it all.
it is an ST185, i am sorry for posting this on a 6gc site but this the largest celica devoted site ive seen, so more likly that someone will know what i have to dfo to fix this. Just freshly rebuild the engine, New bottom end, bore was all good so i left it and a completely redone head.. So 2 months or so age i put it all back together, in 4/5 days. It started first time, ive never had to pick my jaw up from soo far on the on the groud, lol how offten does that happen , unless its on tv.
But anyways all lines, sensors, and connection are all in the right place and working. Everything worked fine first time, no hassels. But now it wont boost
Atm the mods i have done to it are;
Aftermarket dump Pipe
Fueltechnics Fuel Cut Defender
3'' 'dump pipe back' piping, sports exhaust
so i havnt got anything too extravagant, so far....
also and boasting a brand new ct26, so i can slowing retrofit the old one with a new carterige.
So it started after i put the new dump pipe on, took it for a drive, went like the clappers, the fcd was turned upp all the way and boosted to about 16psi, wasnt watching the gaue to busy trin to keep it going up the road straight lol then it went to limp mode the bloody error 34. also blew out one of the exhaust gaskets due to not tightening the bolt up tight enough. ive cleared the codes but it still doesnt boost. ive taken out the fcd, doesnt make a difference. ive checked for cracked boost lines but can not find anything. i will look again tommorrow but is there something im missing or are there someother ideas of what it could be????
Any help from anyone would be greatly appreciated
Cheers
Sam
Replies (1 - 8)
post Dec 17, 2010 - 7:55 AM
check the wastegate flapper, it may be caught on the flange of the downpipe...or your exahust wheel could be in your exhaust.
post Dec 17, 2010 - 3:39 PM
cjh4l22
Joined Oct 18, '06
From cincinnati
QUOTE (presure2 @ Dec 17, 2010 - 7:55 AM) *
x2 same thoughts.
post Dec 17, 2010 - 8:39 PM
Soulend
Joined Nov 24, '07
From Tucson, Az
QUOTE (ST-204R @ Dec 17, 2010 - 1:35 AM) *
This made me feel all warm inside...
Anyway man I hope you figure out your problem.
Kevin
post Dec 17, 2010 - 11:57 PM
TRDGT4
Joined Mar 3, '08
From New Zealand
QUOTE (presure2 @ Dec 17, 2010 - 8:55 AM) *
_______________May COTM 2011_______________
post Dec 21, 2010 - 5:30 AM
ST-204R
Joined May 3, '10
From Orange
Gday, fixed the problem. The end that connects to the waste gate off the actuator snapped. put a new actuator on and problem solved smile.gif
Now my only question left is; how much bosst can a stock engine take before its too much??
Cheer Fellas thank for ur help
post Dec 21, 2010 - 8:51 AM
QUOTE (ST-204R @ Dec 21, 2010 - 6:30 AM) *
sam, your best bet is to get on a dyno, and slowly turn up the boost, and watch your air fuel ratios, while listening for knock.
the ct-26 is your biggest restriction power wise, running 16 or 17psi is not uncommon, more or less in some cases dependant on the motor/fuel/intercooling.
with stock 2nd gen injectors, you will be maxing them out @ ~270 or so whp, which will be hard to get to with the ct-26.
post Dec 25, 2010 - 6:54 PM
ST-204R
Joined May 3, '10
From Orange
QUOTE (presure2 @ Dec 21, 2010 - 9:51 AM) *
Gday, a ct20 isoff a desiel landcruiser or something isnt it?? much work to make it fit and run?? And not that im after all out power, i would still like some aspect of daily driverability. (it isnt my daily driver) so how much power would be expected with a ct20band biger injectors?? also how much bigger should i go??
Cheers
post Dec 27, 2010 - 5:12 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
ct20b from an st205 gt-four... it looks very similar to ur ct26, same fit but it doesnt have a ct marking on the side. in the top end for the same amount of boost you might get very few extra hp but the gains you will notice is that boost builds up more instantly from lower revs and more importantly with less throttle applied
Mike W
269awhp / 273ft-lbs
Lo-Fi Version Time is now: August 4th, 2026 - 10:05 AM
