Dec 26, 2010 - 9:24 PM
![]() Enthusiast ![]() Joined Dec 16, '10 From grand prairie, tx Currently Offline Reputation: 0 (0%) |
Are the letters supposed to light up at night on the auto trans shift indicator? Mine don't and I have to be careful to make sure it's in drive at night. If it is supposed to light up where is the bulb and how do you replace it?
Dec 26, 2010 - 10:04 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 10, '10 From MA Currently Offline Reputation: 37 (100%) |
Dec 26, 2010 - 10:56 PM
Do you know how to replace the bulb for the shift lever?
Dec 26, 2010 - 11:51 PM
sorry if that seemed like an a$$ move, you just have to put it into gear (with the car off, ebrake up) pull the lower dash off, and just find the wires that lead to the bulb, i threw an LED on mine so it will last longer
Dec 27, 2010 - 8:46 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) |
Mine died a while back, but after awhile you'll get used to it, and it wont be a question of what gear you are in. But there is s bulb under the shift bezel. You have to remove the lower bezel, then take off the shifter bezel (4 screws on the sides), Since you still have the stick on its going to be a pain, but you should be able to move the bezel up enough to get to the bulb.
Dec 27, 2010 - 9:47 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 7, '10 From Ft. Lauderdale Currently Offline Reputation: 9 (100%) |
i was wondering if there was a light in there, mine has never worked since i got the car, and it is a pain sometimes when its the middle of the night and your not 100% sure, gotta turn the map light on and squint... (mine isn't too bright.)
Dec 28, 2010 - 4:40 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) |
I drive by feel.
I actually dont recall looking down at the shift lever. I just push the button down once to pass reverse and the shift lever will automatically slide into drive without holding down the button. |
Dec 28, 2010 - 3:29 PM
This was a ver easy fix that only took about a half hour to complete. Bought the bulb at the Toyota dealer. 90981-11014. Turns out there's even a bulb in the coin box. 90981-11018
Dec 28, 2010 - 7:05 PM
I drive by feel. I actually dont recall looking down at the shift lever. I just push the button down once to pass reverse and the shift lever will automatically slide into drive without holding down the button. thats what i usually do, but when im not all there and put it in gear, sometimes i start to second guess myself. -------------------- |
Dec 28, 2010 - 10:03 PM
![]() Enthusiast ![]() ![]() Joined Feb 3, '05 From USA/Virginia Currently Offline Reputation: 2 (100%) |
i did a quick write up for this a few years back. it'll take a num74 led, but you have to file it down a bit.
Mar 5, 2011 - 8:15 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 11, '09 Currently Offline Reputation: 11 (100%) |
only problem with the coin light is well mine was on constantly.
Mar 8, 2011 - 6:16 AM
Enthusiast ![]() Joined Oct 21, '05 From Okinawa, Japan Currently Offline Reputation: 0 (0%) |
AFAIK, the coin light is supposed to be on constantly when the headlights are on.
-------------------- -Dan
1998 SSII Beams, work in progress... |
Mar 8, 2011 - 8:46 AM
PRNDL, as someone else said...once out of park comes reverse, then nuetral, then drive. Its not hard to remember.
| Lo-Fi Version | Time is now: July 29th, 2026 - 6:30 PM |
