> question on a short shifter, short shifter creation
post Jan 7, 2011 - 7:28 PM
playboymma
Joined Jan 7, '11
From Mena, AR
if you remove the stock shifter and cut the bottom rod and weld in a spacer to the rod and compensate for the extension on the plastic seat the shifter sits in will it function just like a short shifter?
I went full retard once, too. Its OK.
- playboymma   question on a short shifter   Jan 7, 2011 - 7:28 PM
- - kevinkoda   http://www.6gc.net/howto/make_custom_short_shifter   Jan 7, 2011 - 9:00 PM
|- - playboymma   QUOTE (kevinkoda @ Jan 7, 2011 - 10...   Jan 8, 2011 - 12:09 PM
- - njccmd2002   RE: question on a short shifter   Jan 7, 2011 - 9:02 PM
|- - HectortheRican   QUOTE (njccmd2002 @ Jan 7, 2011 - 8...   Jan 8, 2011 - 11:51 AM
- - richee3   I want something clarified. You want to cut the ro...   Jan 8, 2011 - 12:56 PM
- - blu94gt   From how I understand, yes it will function like a...   Jan 8, 2011 - 1:10 PM
- - playboymma   QUOTE (richee3 @ Jan 8, 2011 - 1:56 ...   Jan 8, 2011 - 1:19 PM
- - 96stgreendemon   The 7th gen short shifter and spacers work just fi...   Jan 8, 2011 - 1:44 PM
|- - playboymma   QUOTE (96stgreendemon @ Jan 8, 2011 - 2...   Jan 8, 2011 - 1:50 PM
- - richee3   Several members have fitted the 7th gen Celica sho...   Jan 8, 2011 - 1:53 PM
|- - playboymma   QUOTE (richee3 @ Jan 8, 2011 - 1:53 ...   Jan 8, 2011 - 2:00 PM
|- - trdproven   QUOTE (richee3 @ Jan 9, 2011 - 4:53 ...   Jan 12, 2011 - 5:10 AM
- - HectortheRican   What will the brass shifter bearings do for me in ...   Jan 12, 2011 - 9:05 AM
- - 96stgreendemon   you have the riser bushings replaced with the shif...   Jan 12, 2011 - 10:14 AM
|- - HectortheRican   QUOTE (96stgreendemon @ Jan 12, 2011 - 9...   Jan 12, 2011 - 10:16 AM
|- - NOVAKx17   i have the 7gc short shifter installed and for the...   Jan 12, 2011 - 10:26 AM
|- - playboymma   QUOTE (HectortheRican @ Jan 12, 2011 - 1...   Jan 12, 2011 - 5:40 PM
- - HectortheRican   Yeah, I'm definitely doing this. Such a cheap ...   Jan 12, 2011 - 11:24 AM
- - 95CelicaST   Guys, it isn't hard. Go into your engine bay, ...   Jan 12, 2011 - 5:49 PM
|- - HectortheRican   QUOTE (95CelicaST @ Jan 12, 2011 - 4...   Jan 12, 2011 - 7:56 PM
- - richee3   Yes, it really is that easy. If you've never s...   Jan 13, 2011 - 2:06 AM
|- - playboymma   QUOTE (richee3 @ Jan 13, 2011 - 2:06...   Jan 13, 2011 - 3:44 AM
- - 95CelicaST   You could, but honestly just buy a 7th gen short s...   Jan 13, 2011 - 11:29 AM
|- - playboymma   QUOTE (95CelicaST @ Jan 13, 2011 - 12...   Jan 13, 2011 - 1:24 PM
- - EKAn   Where does one get brass shifter cable bushings?   Jan 13, 2011 - 11:40 AM
- - 95CelicaST   I got mine from twosrus.com, which are from speed ...   Jan 13, 2011 - 12:29 PM
- - 95CelicaST   Are you saying you haven't figured out how to ...   Jan 13, 2011 - 1:41 PM
- - playboymma   QUOTE (95CelicaST @ Jan 13, 2011 - 2...   Jan 13, 2011 - 2:25 PM
- - HectortheRican   QUOTE (playboymma @ Jan 13, 2011 - 1...   Jan 13, 2011 - 3:14 PM
- - playboymma   QUOTE (HectortheRican @ Jan 13, 2011 - 3...   Jan 13, 2011 - 5:01 PM
Lo-Fi Version Time is now: August 28th, 2026 - 9:55 AM
