> CT20b boost Q
post Jan 10, 2011 - 5:36 PM
Azncelica
Joined Mar 5, '03
From MPLS, MN
I've got my 3rd gen 3sgte swap done this past year. What I've notices, Turbo don't go full boost until about 3700 rpm. Pulls hard up to redline. I had a buddy with another ct20b turbo. I'd installed on my car. Test drive, It kicks in about 2500 rpm, but notices lack of power past 5k. I'm starting to wonder if my turbo was already mod. or normal.
I also dyno my car. 3 base pulled at 14ps, cheap ebay boost control wasn't holding anymore. I dyno in at about 230hp, miss place actual dyno sheet. For sure it was 230hp or more. Just also wondering where everyone else dyno their car? Only thing that is upgraded is, Went front mount intercooler, Aftermarket down pipe, cat deleted. Full 3' exhaust. and aftermarket radatior. Every else is all stock. Last Also Took my car to the track for the first time. My best time was 14.4 at 99 mph, fastest trap speed was at 103 mph but slower time. No traction, tires spins 1-3rd, finally have traction after 60ft mark. Planing on going with bigger turbo set up this year. Just want to a feel of what everyone have done and try so I can related that to my choices of set up I would like to do. I want my $$$$$$$ count on what ever I do. As we all know, everything for 3sgte and celica isn't cheap.
- Azncelica   CT20b boost Q   Jan 10, 2011 - 5:36 PM
- - DEATH   Full boost [14PSI] at 3700 seems SLIGHTLY late but...   Jan 10, 2011 - 7:35 PM
- - Stambo   I had the exact same 1/4 mile time and trap speed....   Jan 10, 2011 - 8:39 PM
|- - Azncelica   QUOTE (Stambo @ Jan 10, 2011 - 7:39 ...   Jan 11, 2011 - 5:51 PM
- - Sunny   Hi, a fmic have principle more lag against our to...   Jan 11, 2011 - 2:01 PM
- - Stambo   i want to accomplish the same goal as you. Beat a ...   Jan 11, 2011 - 8:05 PM
- - easternpiro1   QUOTE (easternpiro1 @ Jan 25, 2007 - 9...   Jan 11, 2011 - 8:33 PM
- - presure2   3700rpm is really late for a ct20b to spool, even ...   Jan 12, 2011 - 10:38 AM
|- - easternpiro1   QUOTE (presure2 @ Jan 12, 2011 - 10...   Jan 12, 2011 - 4:33 PM
|- - DEATH   QUOTE (easternpiro1 @ Jan 12, 2011 - 3...   Jan 12, 2011 - 4:48 PM
|- - Azncelica   QUOTE (DEATH @ Jan 12, 2011 - 3:48 P...   Jan 12, 2011 - 5:27 PM
- - Azncelica   Got a chance to post some vid from my time at the ...   Jan 13, 2011 - 2:34 AM
|- - DEATH   QUOTE (Azncelica @ Jan 13, 2011 - 1...   Jan 13, 2011 - 7:46 AM
|- - Azncelica   QUOTE (DEATH @ Jan 13, 2011 - 6:46 A...   Jan 13, 2011 - 10:08 AM
- - delusionz   when i had ct20b it used to spring to life at abou...   Jan 13, 2011 - 4:28 AM
|- - Azncelica   QUOTE (delusionz @ Jan 13, 2011 - 3...   Jan 13, 2011 - 10:16 AM
- - DEATH   Alot of your vids cut off your times - could you p...   Jan 14, 2011 - 10:20 PM
|- - Azncelica   QUOTE (DEATH @ Jan 14, 2011 - 9:20 P...   Jan 14, 2011 - 11:44 PM
- - delusionz   46mm compressor steel turbine and shaft   Jan 16, 2011 - 3:29 AM
Lo-Fi Version Time is now: June 10th, 2026 - 8:46 AM
