Jan 16, 2011 - 8:45 AM
![]() Enthusiast ![]() Joined Dec 16, '10 From grand prairie, tx Currently Offline Reputation: 0 (0%) |
The third generation celica with the 22R enginge was mounted longitudaly. Would a swap be possible with a JDM 3SGE motor? How much trouble would it be to mount it. I assume the existing motor mounts would not line up. what about the transmission? Would the original tranny work?
Jan 16, 2011 - 8:49 AM
Enthusiast ![]() ![]() Joined Sep 11, '08 From Surrey Unitedkingdom Currently Offline Reputation: 1 (100%) |
Think on this your best bet would be to sourse the gearbox from an Altezza and the sump as these are the main things you will need for this. |
Jan 16, 2011 - 1:05 PM
Are you thinking of the Blacktop BEAMS? You would need everything from the Altezza. The 22R had no electronics, no FI, nothing. The Blacktop does, so you've got quite a bit of work set out for you. But people can and have done the swap. You could probably find some information for it on Celicatech.
| Lo-Fi Version | Time is now: September 7th, 2026 - 5:04 AM |
