Jan 20, 2011 - 2:05 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
So im still a little confused on what all is involved when swapping the wiring from the 7a to the 4age.
The wiring harness has to be extended and some parts of the 7a tied into it correct? Just confused on what all is involved in the task, if someone could clear this up for me it would be greatly appreciated -------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
96stgreendemon Swap harness question Jan 20, 2011 - 2:05 PM
richee3 The wiring harness doesn't necessarily have to... Jan 20, 2011 - 2:25 PM
96stgreendemon Ok let me get this, so does the ecu just connect t... Jan 20, 2011 - 2:52 PM
PhoenixTech QUOTE (96stgreendemon @ Jan 20, 2011 - 3... Jan 21, 2011 - 11:48 AM
96stgreendemon Yeah its going to be a 20v swap, you have mail Jan 21, 2011 - 3:42 PM
95CelicaST As I stated in another thread, mr220v on mr2oc and... Jan 21, 2011 - 4:12 PM
PhoenixTech QUOTE (96stgreendemon @ Jan 21, 2011 - 3... Jan 21, 2011 - 5:55 PM
richee3 Definitely swapping a 20V in, Kyle? Jan 22, 2011 - 1:31 PM
96stgreendemon Its looking that way, still looking between a silv... Jan 22, 2011 - 1:53 PM
richee3 Awesome! I've been trying to convince peop... Jan 22, 2011 - 2:08 PM
96stgreendemon Yeah, and it just seems like there are not enough ... Jan 22, 2011 - 2:30 PM
SupraKid Youll be the first DOCUMENTED swap, if you do do i... Jan 22, 2011 - 3:57 PM
96stgreendemon Eh i was looking at a rebuild on the 7a, but by th... Jan 22, 2011 - 5:05 PM
95CelicaST 160ish from a Blacktop?
Try 135whp. For real. Jan 22, 2011 - 8:26 PM
richee3 ^^ Which is what the 5S gets to the crank. Not a b... Jan 23, 2011 - 10:42 AM
lagos QUOTE (richee3 @ Jan 23, 2011 - 10:4... Jan 23, 2011 - 11:46 AM
richee3 QUOTE (lagos @ Jan 23, 2011 - 12:46 ... Jan 23, 2011 - 6:10 PM
95CelicaST The 20v is a cool swap for a show car, but in real... Jan 23, 2011 - 1:08 PM
96stgreendemon Yes i know that its not a big improvement, but im ... Jan 23, 2011 - 4:49 PM
95CelicaST Figure about 40whp, but the torque curve isn't... Jan 23, 2011 - 6:25 PM
96stgreendemon Wait, it feels slower? Jan 24, 2011 - 10:05 AM
delusionz 20v's heavily rely on the close ratio gear box... Jan 24, 2011 - 11:38 AM
96stgreendemon Im planning to use the 5 speed LSD transmission th... Jan 24, 2011 - 11:40 AM
95CelicaST the 5sp is still a c52 transmission, so unless the... Jan 24, 2011 - 1:41 PM
96stgreendemon Bump, anyone with a 20v have any imput? i know the... Jan 24, 2011 - 2:10 PM
SupraKid Netrata in the 808 has a silvertop Jan 24, 2011 - 2:18 PM
95CelicaST When I had the Yelli Celi dynoed it put down 130wh... Jan 24, 2011 - 2:24 PM
96stgreendemon Hmm..... Well depending on the price difference i ... Jan 24, 2011 - 2:32 PM
delusionz silvertop vs blacktop?? the torque is the same. ho... Jan 24, 2011 - 5:50 PM
95CelicaST Wrong.
Peak power is made in the 6k rpm range...... Jan 24, 2011 - 6:00 PM
delusionz QUOTE (95CelicaST @ Jan 25, 2011 - 11... Jan 24, 2011 - 11:34 PM
presure2 swap a 4a, be prepared for disappointment.
you won... Jan 24, 2011 - 6:25 PM
96stgreendemon So basically the 4age is just a waste of money? Jan 24, 2011 - 7:23 PM
SupraKid Not if you HAVE to rebuild your 7afe...I mean yes ... Jan 24, 2011 - 8:42 PM
95st-celica if your looking for an N/A motor to build and keep... Jan 24, 2011 - 8:53 PM
96stgreendemon Im in need of a rebuild, but i also need to look a... Jan 24, 2011 - 9:24 PM
95CelicaST Webcams isn't going to get you cams for a 20V.... Jan 24, 2011 - 11:24 PM
SupraKid Kyle do you plan to swap the tranny as well?Or kee... Jan 24, 2011 - 11:24 PM
97lestyousay The 4a is a good motor I would take a 16V 4AGE ove... Jan 25, 2011 - 12:32 AM
richee3 It wouldn't be that much more difficult to swa... Jan 25, 2011 - 1:22 AM
njccmd2002 4A Swaps sound cool and all, but really, what are ... Jan 25, 2011 - 2:31 AM
SupraKid You guys are looking at this like he wants to swap... Jan 25, 2011 - 4:47 AM
njccmd2002 two things..
Whatever rocks your Boat!
Do it... Jan 25, 2011 - 5:03 AM
96stgreendemon Here is the thing, yes like i have said and suprak... Jan 25, 2011 - 11:48 AM
Keiri If those are your reasons then I'd say you... Jan 25, 2011 - 1:14 PM
HectortheRican I used to be so set on swapping in a 20V, but afte... Jan 25, 2011 - 3:03 PM
96stgreendemon I still plan to go with the 20 valve now, i actual... Jan 26, 2011 - 5:39 PM
96stgreendemon Bump.... back on topic, does anyone know which wir... Feb 1, 2011 - 9:06 AM![]() ![]() |
| Lo-Fi Version | Time is now: July 12th, 2026 - 5:58 AM |
