> Help with Engine movement!, Another Kirkosaurus mounts question?
post Jan 22, 2011 - 8:22 AM
str8thugginit4ya
Joined Dec 11, '07
From Davie, Florida
Hey guys,
I have a 94 Celica GT with a 3SGTE in it. The mounts were really bad, so I bought Kirk's engine mount inserts to help with the engine movement. This is my 2nd time buying the inserts and the first time, they held that motor down like a 250lb man putting a bear hug on a 110lb boy! But this time, I'm not getting that same result. One thing I should tell you is that the front mount was not an original 94-99 GT mount, it was the mount from the 5th gen's. The bracket that the mount attaches to was for the 6th gen, so the insert was a little bit thick to fit in. So I shaved the sides of the inserts down a LITTLE bit just to fit it in. Would this play any part on why the inserts isn't holding the engine? I mean, I felt a little difference when I installed the inserts, but there is still a good amount of engine movement if I do not time the shift exactly correct. Could my side mounts be bad? Any input would be greatly appreciated.
-Thanks for your time, Ryan
post Feb 10, 2011 - 4:21 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
what you mean isnt holding the engine? you'd hear a loud thud every time you accelerate or braked if it wasnt holding the engine lol
you mean you want your car to vibrate and rattle like a race car but it doesnt?
or it vibrates and rattles and you don't like it?
Mike W
269awhp / 273ft-lbs
Lo-Fi Version Time is now: August 22nd, 2026 - 9:15 PM
