Jan 23, 2011 - 6:43 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
I tried installing my brass shifter bushings today and I was able to get the linkage arm and the old rubber bushing off, but the brass sleeve inside the old rubber bushing stayed firmly stuck on the pin connecting to the tranny. I tried generous amounts of WD40 and pliers and I pulled and twisted for about half an hour and it wouldn't budge. Any ideas?
This post has been edited by HectortheRican: Jan 24, 2011 - 9:32 AM -------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
Jan 23, 2011 - 6:59 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
So the brass ring that was inside the oem bushing stayed on the pin when you lifted it off?
Picture? -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Jan 23, 2011 - 7:22 PM
Yessir. And it was getting dark so I put everything back together. I should've thought ahead and taken a picture. But it's just a brass sleeve on the pin itself that I'm assuming is really rusted on. If the area wasn't so damn constrained it wouldn't be too difficult, but I can barely move my hand in the area. This post has been edited by HectortheRican: Jan 23, 2011 - 7:22 PM -------------------- taking too long to mod since '09
Jan 23, 2011 - 7:31 PM
hammer and chisel? Tap the thing loose?
Jan 23, 2011 - 7:35 PM
hammer and chisel? Tap the thing loose? If there was room... There's literally NO room. Room enough for one hand and a stubby flathead screwdriver. -------------------- taking too long to mod since '09
Jan 24, 2011 - 9:04 AM
yup, thats pretty common, lots of PB blaster, maybe a little heat (CAREFUL AROUND THE FUEL LINES!!!) a sharp chisle, screwdriver, vice grips, pliers, or whatever, screaming, cursing, and drinking, just try to get it working back and forth, then wedge it up and off.
try not to squeeze it with pliers/vice grips TOO much, your just making it harder to get off when you do. :edit: also, it helps to properly title your threads. that way, people know what your problem is, before they click the thread, and it helps in future searches. -------------------- Former Team 5SFTE pro member ;)
yup, thats pretty common, lots of PB blaster, maybe a little heat (CAREFUL AROUND THE FUEL LINES!!!) a sharp chisle, screwdriver, vice grips, pliers, or whatever, screaming, cursing, and drinking, just try to get it working back and forth, then wedge it up and off. try not to squeeze it with pliers/vice grips TOO much, your just making it harder to get off when you do. :edit: also, it helps to properly title your threads. that way, people know what your problem is, before they click the thread, and it helps in future searches. Thanks, all good tips. Especially the cursing -------------------- taking too long to mod since '09
Jan 24, 2011 - 10:04 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
Yeah like i said, i used vise grips and lots of pb blaster
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
Jan 24, 2011 - 11:22 AM
All I have is WD40 at the moment. Looks like another trip to the store..
Jan 24, 2011 - 11:25 AM
yea, once you use PB, you'll have no use for WD-40.
at least not for getting bolts off. PB is a penetrating solution, WD isnt nearly as good for that. a can of PB Blaster, a few tools, a torch and lots of patience, and you can get almost any bolt out thats rusted or siezed in place. -------------------- Former Team 5SFTE pro member ;)
Jan 24, 2011 - 11:28 AM
Propane torch, pb blaster, and brake cleaner. It's all you'll ever need.
Jan 24, 2011 - 11:30 AM
I wish I could get a super awesome set of tools and supplies but alas, I live in a college dorm. There's no room for that stuff
Jan 24, 2011 - 11:41 AM
4 drawer craftsman toolbox + a small cardboard box to hold my aerosol cans (paint, cleaners), propane can, and a large pry bar. It'll all easily fit in your trunk. Hell, it fits in the mr2's trunk.
Jan 24, 2011 - 11:46 AM
Lol my best friend has a '91 MR2 N/A as well, he's a bit on the chubby side, I tease him that he can't even go grocery shopping for himself with that trunk lol. He gets so mad -------------------- taking too long to mod since '09
| Lo-Fi Version | Time is now: September 2nd, 2026 - 1:14 AM |
