Jan 25, 2011 - 11:26 AM
Enthusiast ![]() ![]() ![]() Joined Dec 11, '07 From Davie, Florida Currently Offline Reputation: 4 (100%) |
Hey guys,
I was re-routing my battery to my trunk yesterday and after everything was complete, everything started up fine and was getting power to everything. I have a 150 amp ANL fuses on each side of the re-routing power wire. So if there's a short on either side, I should be protected. THE PROBLEM: is after I got everything installed, I realized that none of my interior lights was working. The lights on the a/c panel & the gauges are working. Just the door lights, trunk interior light, and main dome light is out & not coming on at all. I checked fuses and all are fine, what else could be causing the lights to cut out? Any help would be appreciated. EDIT: I believe now that my problem maybe an ignition problem. My headlights won't turn on, unless I turn my key all the way to the "on" position. Plus, now I am getting a "hard start." Like my battery is about to die, but I just put in a new one when I relocated my battery position. I'm thinking, maybe it's a relay or something like that? Please, I need your help! -Thanks, Ryan This post has been edited by str8thugginit4ya: Feb 7, 2011 - 1:48 PM |
str8thugginit4ya Ignition Problem??? Jan 25, 2011 - 11:26 AM
95CelicaST Did you actually test the fuses? Or just a visual ... Jan 25, 2011 - 11:36 AM
str8thugginit4ya Just visually. I was thinking it was a fuse proble... Jan 25, 2011 - 11:44 AM
mkernz22 You check them by pulling them out and seeing if t... Jan 25, 2011 - 12:44 PM
str8thugginit4ya QUOTE (mkernz22 @ Jan 25, 2011 - 1:4... Jan 25, 2011 - 5:00 PM
95CelicaST Yeah I've had some that look fine, but are act... Jan 25, 2011 - 1:24 PM
mkernz22 Well hey, you just never know sometimes
If the ta... Jan 25, 2011 - 5:30 PM
str8thugginit4ya Ok, so I went & replaced a bunch of fuses, but... Jan 26, 2011 - 8:06 AM
mkernz22 The dome light has it's own fuse because I bel... Jan 26, 2011 - 8:44 AM
str8thugginit4ya QUOTE (mkernz22 @ Jan 26, 2011 - 8:4... Jan 27, 2011 - 8:22 AM
mkernz22 When you open your doors does it make a bing, bing... Jan 27, 2011 - 10:51 AM
str8thugginit4ya Nope, the ignition is not working properly. It sta... Jan 27, 2011 - 11:36 AM
mkernz22 someone probably unplugged the wire that makes it ... Jan 27, 2011 - 2:00 PM
str8thugginit4ya QUOTE (mkernz22 @ Jan 27, 2011 - 3:0... Jan 27, 2011 - 4:59 PM
str8thugginit4ya Could it be an ignition relay or something like t... Jan 28, 2011 - 9:07 AM
str8thugginit4ya Bump! Please help, I am out of ideas.
-Thank... Feb 1, 2011 - 8:46 AM
tjblacrosse We just talked a little about this so I thought I... Feb 1, 2011 - 11:06 AM
Neon90424 I had the bing bing bing thing removed it was driv... Feb 1, 2011 - 12:07 PM
trdproven theres also a fuse that is labeled "X" y... Feb 1, 2011 - 8:01 PM
str8thugginit4ya QUOTE (trdproven @ Feb 1, 2011 - 9:0... Feb 3, 2011 - 12:30 PM
PluraticRaver From where your battary was, How did you hook up t... Feb 4, 2011 - 9:26 AM
str8thugginit4ya Fixed the problem! It wasn't a fuse proble... Feb 7, 2011 - 1:47 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 11th, 2026 - 10:17 AM |
