Jan 29, 2011 - 10:46 PM
Enthusiast ![]() Joined Jan 10, '11 From Trail BC Currently Offline Reputation: 1 (100%) |
K, so motor is in car everything ready 2 go, just waiting on Dr. Tweak 2 send back my wire harness 2 hook up n start....find out now that engine will throw a code cause cannot read IC Pump, and ECU will go into some kind of protection mode, and not allow 2 go over 7psi on turbo...????
Question is: Is there a way for Dr. Tweak 2 bypass this, so that the ECU is tricked, and will not know the wiser.... OR, The bosch waterpump I have set-up on the car already, run off a toggle switch inside the car, can he make it so the ECU reads that pump instead..... Remember, I dont have the relay box or relay, that apparently mounts on the Rad. There has 2 be a way. Any Info?????????????????????? |
injection charge cooler waterpump?????? Jan 29, 2011 - 10:46 PM
presure2 he "should" be able to do it,but he trie... Jan 30, 2011 - 7:21 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 26th, 2026 - 6:51 AM |
