Jan 30, 2011 - 10:28 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
I've seen 18x10 work on a st185. I know these are completely different chassis, but on the offset guide thats stickied 9" wide wheels wont fit regardless of the offset is what is stated. Just need help on this because I am switching to a 5x114 lug pattern to run a more variety of wheels and plan to use the car for the track. Of course the celica will be lowered too.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Jan 30, 2011 - 10:46 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 13, '08 From Australia Currently Offline Reputation: 7 (100%) |
Just need help on this because I am switching to a 5x114 lug pattern to run a more variety of wheels and plan to use the car for the track. Of course the celica will be lowered too. Well having spacers which is what im assuming thats the way your going to switch to the 114.3 lug patterm is a big no no. But to answer your question yes they will fit rolled. -------------------- |
Jan 30, 2011 - 12:04 PM
Just need help on this because I am switching to a 5x114 lug pattern to run a more variety of wheels and plan to use the car for the track. Of course the celica will be lowered too. Well having spacers which is what im assuming thats the way your going to switch to the 114.3 lug patterm is a big no no. But to answer your question yes they will fit rolled. Ur wrong rav4 front hubs all the way around with the awd conversion since the same wheel bearing for the front of the celica is used all the way around. Rav4 is 5x114 On the other hand for the FWD celicas you guys could venture off by using camry spindles all the way around. Camrys use a far bigger wheel bearing and maybe use rav4 brakes? This post has been edited by bccentaur3: Jan 30, 2011 - 5:43 PM -------------------- 98 Celica gt red- totaled deer
Jan 30, 2011 - 2:28 PM
If they will fit with rolled fenders will I need a spacer to bring it out to the correct offset to sit flush?
Jan 30, 2011 - 6:04 PM
K, read through the offset guide again and a user had the wheel size I plan on running with no issues.
| Lo-Fi Version | Time is now: May 27th, 2026 - 12:46 PM |
