Jan 30, 2011 - 3:37 PM
Enthusiast ![]() ![]() Joined Aug 22, '07 From Burnaby, British Columbia, Canada Currently Offline Reputation: 8 (100%) |
I was wondering if anyone could help me with this. I have a JDM GT-four and drive on the right hand side. Sometimes while driving I hear a sound like water swooshing around in the engine, towards the passenger side of the car (left hand side). At first I thought it could be the W2A intercooler...but it's topped off..and any water movement won't make that loud of a sound...then I thought i was crazy (lol) but other ppl hear it too haha..
It just sounds like water moving in a mostly empty reservoir... -------------------- |
Jan 30, 2011 - 3:51 PM
windshield washer tank?
Jan 30, 2011 - 4:09 PM
Enthusiast ![]() ![]() ![]() Joined Apr 23, '08 From boston MA Currently Offline Reputation: 5 (100%) |
you may need to bleed your system if air is in the heater core you will hear sloshing sound....turn the climate control to hot take the cap off an try to get it to burp and add coolant
Jan 30, 2011 - 4:34 PM
you are low on coolant or you have air in the system. its water rushing into the heater core
Jan 30, 2011 - 4:37 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 10, '10 From MA Currently Offline Reputation: 37 (100%) |
heyyy, this is good help for me. i've noticed that sound for a while and never really thought of it
Jan 30, 2011 - 5:53 PM
windshield washer tank? no the sound is there even when the tank is topped you may need to bleed your system if air is in the heater core you will hear sloshing sound....turn the climate control to hot take the cap off an try to get it to burp and add coolant sounds good. I will try this! you are low on coolant or you have air in the system. its water rushing into the heater core Thanks! -------------------- |
Jan 30, 2011 - 7:30 PM
I need to do this as well, need to burp my baby
Jan 30, 2011 - 7:38 PM
is it bad that there is an air bubble in them?
Jan 30, 2011 - 7:47 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 15, '10 From The Best Coast Currently Offline Reputation: 12 (100%) |
Thats one more area coolant could be to help cool the engine..
Jan 31, 2011 - 2:58 AM
so to drain the W2A intercooler..there's a cream colored plastic thing near the foglights on the drivers side of the car (right side) that needs to be unscrewed...
where is the plug to drain the radiator? should i do this also while I'm at it? toyota red for life coolant for both? how many liters? -------------------- |
Feb 1, 2011 - 2:43 AM
anyone have answers that i seek?
Feb 1, 2011 - 8:31 AM
lol quit asking things at 3AM.
the radiator drain plug is located typically near the bottom of the radiator. on my corolla it was on the drivers side and, sticking in towards the engine from the plastic side tank. On my Celica (7th gen) it's in a similar spot, my Mazda is also in a similar spot. If it won't open then just take off the lower radiator hose at the radiator. -------------------- |
Feb 1, 2011 - 6:14 PM
haha it was 11:43PM for me when i posted
Thanks! I will look into it This post has been edited by nammer: Feb 1, 2011 - 6:14 PM -------------------- |
Feb 14, 2011 - 10:07 AM
Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '10 From Raleigh Currently Offline Reputation: 12 (100%) |
That is so weird. I've been hearing the same thing in my car too. It's only when I start accelerating from a stop. I guess I'll go bleed again. I just finished putting a Koyo in the car.
Aug 4, 2011 - 6:54 PM
![]() Enthusiast Joined Oct 10, '06 From Portland, OR Currently Offline Reputation: 4 (100%) |
Had the same problem with some occasional high temp problems. Burped and now everything is back to normal and no wooshing sounds. Thanks guys!
-------------------- Augusto
Aug 4, 2011 - 7:35 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
mines been doin sht like this forever, spits its coolant out the overflow and overheats,...
going to have a custom swirlpot and high mounted header tank made and if that doesnt fix it, ill simply inject my cooling system with a regulated 1.2bar feed from my ice tank into my thermostat housing and call it a day, ... -------------------- Mike W
| Lo-Fi Version | Time is now: September 8th, 2026 - 4:06 AM |
