> Power window is having trouble going up
post Feb 5, 2011 - 9:30 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
Today when I went to make my window go up, about halfway, it stopped. So I took it back down a bit and brought it back up and I could hear the gears inside slipping and slowly but surely, my window made it back up. Would this be that the gears are loose? Or is the motor going bad? It's the driver side window, if that's relevant.
June '12 COTM
'95 AT200
Replies (1 - 17)
post Feb 5, 2011 - 10:05 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Do you hear any type of grinding noise?
post Feb 6, 2011 - 8:10 AM
Neon90424
Joined Jan 19, '11
sorry to thread jack but my windows suck too, If I put them up at the same time you could time them with a calendar...
post Feb 6, 2011 - 12:16 PM
schmooot
Joined Sep 29, '09
From Prince George, BC CANADA EH!
most of the time it is just a worn out motor, but it is worth opening up the door and removing the motor and bench testing it. That will eliminate things like wiring, relays, battery/alt issues. Then make sure everything inside the door is lubed up nicely, sometimes the tracks and runner dry out if you have a faulty window seal or something
ST205 Crew represent
Challenge Accepted
post Feb 6, 2011 - 12:37 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Or a bad strand of wire. Thats my ordeal now. Wire in the twist decided to snap, going to replace that soon. For when you guys do get around to changing out the motors, cables, etc....here ya go I'll save you the trouble of having to search.
post Feb 6, 2011 - 2:29 PM
HectortheRican
Joined Dec 26, '09
Thanks Josh!
June '12 COTM
'95 AT200
post Feb 7, 2011 - 2:14 AM
SoDo
Joined Dec 16, '07
From Chicago, IL
I had the same problem before. Window would get stuck going up and down in certain spots. The problem was caused by a fray in the regulator cable. I replaced the whole motor/regulator with one I found in a junk yard and it solved the problem.
1999 Celica GT Hatchback
post Feb 7, 2011 - 6:42 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
See, there ya go, pop the door panel and actuate the window while looking at the cable. If its birdcaged or you have a strand broke, you know what your problem is off the bat.
post Feb 8, 2011 - 11:17 AM
tim86
Joined Oct 31, '03
From Orlando, Florida
my regulator is still bad too... been trying to get around to fixing it but im giving it a bit more time since its not quite warm out yet!
post Feb 8, 2011 - 12:01 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
This is why i love manual windows and locks lol, hopefully you get this fixed hector
2001 Solar yellow Lexus IS300
post Feb 8, 2011 - 12:08 PM
HectortheRican
Joined Dec 26, '09
QUOTE (96stgreendemon @ Feb 8, 2011 - 11:01 AM) *
Lol thanks Kyle. As soon as it gets a bit warmer, I'll take a look.
June '12 COTM
'95 AT200
post Feb 8, 2011 - 1:05 PM
samir0189
Joined Mar 8, '08
Does this only happen when its cold outside? If so, my passenger side window does the same thing. It will move terribly slow, sometimes it stops, and then it takes a few minutes before it will move again.
I'm wondering if something like grease is freezing???????
My F/S Thread!
Ferdi says (11:29)
post Feb 8, 2011 - 2:08 PM
HectortheRican
Joined Dec 26, '09
QUOTE (samir0189 @ Feb 8, 2011 - 12:05 PM) *
Maybe... I haven't tried it again since Saturday because I'm a bit worried that I won't be able to force it up next time LOL
That would be a good explanation though because I NEVER noticed any hesitating from the driver's side window, it was perfect. And then one day it was all THHHPPPPT. And it has been unusually cold here lately... so I'll check again.
This post has been edited by HectortheRican: Feb 8, 2011 - 2:09 PM
June '12 COTM
'95 AT200
post Feb 8, 2011 - 8:10 PM
Neon90424
Joined Jan 19, '11
My passenger window is the sluggish one of the 2 aswell
post Feb 8, 2011 - 8:38 PM
HectortheRican
Joined Dec 26, '09
QUOTE (Neon90424 @ Feb 8, 2011 - 8:10 PM) *
Normally my driver window is the perfect one and my passenger window is the slugglish one as well.
June '12 COTM
'95 AT200
post Feb 14, 2011 - 6:59 PM
HectortheRican
Joined Dec 26, '09
I haven't had time to check anything in the door panel, but I tested it today because the weather has been getting warmer and it went up and down, but around halfway up, there's a slight grinding sound. But it actually goes up and down again lol
June '12 COTM
'95 AT200
post Feb 15, 2011 - 9:57 AM
tim86
Joined Oct 31, '03
QUOTE (HectortheRican @ Feb 14, 2011 - 6:59 PM) *
The cable is probably fraying and it will work for prob another 3-6 months but after that it will lock up and the cable will be about done. Thats what happened with mine, I'm finally just about to replace it in time for spring!
post Feb 15, 2011 - 12:10 PM
HectortheRican
Joined Dec 26, '09
Damn.. well I'm going to have to make time soon and scope out the situation.
June '12 COTM
'95 AT200
Lo-Fi Version Time is now: August 1st, 2026 - 9:53 AM
