> Strange sound, Rear brake problem
post Feb 11, 2011 - 7:50 AM
jackkasper
Joined Dec 16, '10
From grand prairie, tx
Everytime I apply the brakes I hear a strange clunking sound from the right rear tire area. Any idea what's making the sound?
post Feb 13, 2011 - 12:51 PM
Euphoria
Joined May 6, '08
From Lisarow, NSW, Australia
Most likely the pad and caliper is moving around, I had this happen recently, take everything off and put copper grease on both brake pads ends on both sides, then over the clips put anti brake squeal, whilst you're at it put the correct
grease in the sliding pins and everything should be sorted.
post Feb 13, 2011 - 1:17 PM
D-Man
Joined Jan 18, '08
From Houston
could also be bearings.
Damn D-Man - most impressive.
post Mar 13, 2011 - 4:05 PM
zfjohnson07
Joined Apr 11, '09
hate to bring this one back up but im having problems like this with mine, i mentioned in another one that i didnt have the shims, well i called about 100 places and found some and put them on, and like i said put new rotors on my car. it stops but when i stop it makes a noise like the pads dont catch for a second, so i took it off and checked everything again and it seemed fine. i made a video if you listen for a couple seconds the first noise is my dashboard shaking, yesi need new mounts. http://www.youtube.com/watch?v=plRLa-9_BHc ... tell me what you think
thank you
Lo-Fi Version Time is now: August 29th, 2026 - 6:24 AM
