Feb 13, 2011 - 9:59 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) |
There is a kit at toyota, but it cost $50-up and i find it that this product i used was cheaper and does the same thing. nice tune up for the summer. This will kill bacteria, mold...etc and act like a de-greaser to get rid of dirt and other nasty things in there.
Go to Lowe's to find this cleaner...other hardware store might have it, but it is expensive there...online it cost $50...or more...at Lowe's ----> $5-7 after tax. Frost king ac foaming cleaner Materials used: 1.) frost king air conditioner coil cleaner *19 oz. aerosol foaming type (lemon smells like) [/b] ![]() 2.) Screw driver (4-sided) 3.) napkins for wiping THAT's all. First open your glove department. Two screw on the bottom and three on top...pull it down and take off necessary clips...i would disconnect the battery since there is an airbag wiring located on the top of the glove department. look at the bottom to find the blower resistor like this with two 4-sided screws: ![]() Unscrew it off... ![]() then simply spray in it with the cleaner....it'll foam up and let it sit for 5-10 mins....i practically spray the whole can... go back and put it in....screw the two screws back in place...plug in the battery and turn on your car.... Dry the evaporator for 30 minutes with the following settings: AC: . . . . . . . . . . . Off Air Outlet: . . . . . Foot Mode: . . . . . . . . . Recirc. Blower: . . . . . . . High Temp: . . . . . . . . . Max Warm Windows: . . . . . Closed Open windows for ventilation if cleaner has strong smell. Do not turn on the AC switch until the evaporator is completely dry as this can reduce the effectiveness of the solution. Put glove department back on and you are done....recommend to clean every 2 years, but i say just do it every time you have a funky smell...it's a 1/2 hour job and it cost $5-7 for cleaner air since we don't have any cabinet filters to help out.... Repeat the process with another can or if you have some left to get a cleaner core if needed. This post has been edited by chacha: Feb 14, 2011 - 12:38 AM |
chacha How to clean your Evap core for the summer without having to take out Feb 13, 2011 - 9:59 PM
Rusty awesome job (added to the stickies) Feb 14, 2011 - 12:07 AM
richee3 Nice writeup! Considering the age of our cars ... Feb 14, 2011 - 3:10 AM
chacha this is pretty much where and how the guys at the ... Feb 14, 2011 - 6:37 AM
HectortheRican I love it!! I'm doing this once it sta... Feb 14, 2011 - 9:31 AM
mkernz22 I'm going this in the Spring! Great write ... Feb 14, 2011 - 10:27 AM
njccmd2002 i actually bought a double system online for 35 bu... Feb 14, 2011 - 5:01 PM
chacha yeah...that'll work too...eh...5-7 dollars....... Feb 14, 2011 - 6:38 PM
richee3 Letting mine dry right now The smell of the foam ... Apr 18, 2012 - 4:16 PM
trdproven bought an evap core from ebay for 30 bucks or some... Apr 18, 2012 - 6:36 PM
richee3 My a/c definitely wasn't smelling funky or any... Apr 19, 2012 - 10:15 PM
BK94ST The Toyota kit is also 2 parts. Foaming spray is s... Apr 20, 2012 - 12:46 PM
Special_Edy Lol I have a couple cans of the Frost King sitting... Apr 20, 2012 - 1:14 PM
nics QUOTE (BK94ST @ Apr 20, 2012 - 10:46... Apr 17, 2013 - 12:48 PM
Box Awesome, next time I'm at the Wal-Mart that ca... Apr 21, 2012 - 1:50 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 25th, 2026 - 3:34 AM |
