> <'95 OBD (or whatever) serial/USB cable, need to connect my Celi to a carPC
post Feb 16, 2011 - 8:59 AM
quick_5hifter
Joined Mar 13, '09
From Constanta, Romania
Hello everyone!
Last couple of weeks I've been setting up a car PC for my Celica.
The car is a '95 ST202 with the non-VVTi 3sge engine (129kw/175 HP).
The car PC will be permanently installed in the car, so I've been thinking of connecting it to the car somehow, to be able to use it for diagnose and stuff.
I need to know if that is possible for the pre'96 Celicas, if there is any cable available, along with some software. I've done a couple of diagnoses so far, in a specialized garage, so I'm sure the under-hood connector is good for something biggrin.gif
If you think / know it isn't possible, do you recommend changing my ECU with some '96+ ECU that runs OBD2? Is it possible to replace the ECU only?
Would it be possible to connect my PC to some "piggy-back" ECU or should I go for some stand-alone engine management system?
PS: I know that I could buy some diagnostics kit for Toyota (including a tester/mini-computer that is specially designed for diagnostics) along with the cables required, but that would cost a fortune so it's out of discussion.
PS2: Didn't find any answer for my questions by using the "Search" function.
Thank you for your time and possible answers!
Lo-Fi Version Time is now: May 24th, 2026 - 12:29 PM
