> When did you replace your struts?
post Feb 25, 2011 - 2:53 AM
pflau
Joined Apr 8, '03
From New York City
Some guy at Mavis said to me my Celica's struts needed to be replaced. He said that though my car had relatively low mileage (75K) it was 11 years old and is due for the struts to be replaced. I kept doing that lean on fender, bounce the car up and down, and see if it stops after one bounce test, and I just couldn't see how the struts needed replacement. My car doesn't lean during corner, doesn't nose dive when stops, doesn't float like a boat when going over bumps. So how long did your struts last??
This post has been edited by pflau: Feb 28, 2011 - 4:06 PM
Replies (1 - 19)
post Feb 25, 2011 - 9:26 AM
azian_advanced
Joined Apr 18, '05
From Calgary
i can never trust the bounce test.. i prefer pulling out the struts to check if they're still good or not.
post Feb 25, 2011 - 10:59 AM
block
Joined Jul 27, '06
From Soda
Replaced mines at 198k. Yours sound like they're fine.
post Feb 25, 2011 - 1:29 PM
xrav22
Joined Jul 24, '08
From Canoga Park CA.
QUOTE (block @ Feb 25, 2011 - 10:59 AM) *
The bounce test was designed for shocks not struts. It never works because the spring is under too much pressure. My struts were bad and I noticed by driving on the freeway and if your car bounces or vibrates over bumps(405 freeway a good test) or you bottom out then replace. After I replaced no more bouncing.
post Feb 27, 2011 - 10:57 AM
block
Joined Jul 27, '06
From Soda
Well yeah, I replaced my whole suspension because it was too bouncy. 198k is an awfully long period of time to replace any suspension components.
post Feb 27, 2011 - 10:28 PM
cyberblader1130
Joined Oct 24, '09
From Appleton, Wisconsin 54915
Replaced mine at 105k just because i was lowering on Tiens and didn't trust my stock ones. They were still good, i just didn't want to use them.
post Feb 28, 2011 - 12:42 AM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
I replaced mine at about 99k. They were bouncy and noisy and annoying.
June '12 COTM
'95 AT200
post Feb 28, 2011 - 2:01 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
3months ago, 3months before that, then another 3, then 6 before that one..........
post Feb 28, 2011 - 3:51 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
I had leaking shocks from 160,000 Kms (100,000 miles)
Handling-wise the car still held the road very good, but was a bit loose compared to before.
The advice i got was to wait until it got worse as the leak was ever so slight i managed to hold out until 180,000kms for a set of coilovers at which stage the old struts were broken in a couple places
Mike W
269awhp / 273ft-lbs
post Feb 28, 2011 - 4:06 PM
pflau
Joined Apr 8, '03
From New York City
QUOTE (xrav22 @ Feb 25, 2011 - 12:29 PM) *
I am not sure what you mean by bottom out.. 3 of my 4 rims are bent at the lip, is it an indication? I don't really trust Mavis because I heard they like to upsell you stuff.
post Mar 4, 2011 - 6:11 PM
RavenAegis45
Joined Jun 25, '08
From CA
Well I replaced my struts when I noticed an Unusual liquid covering my rear suspension, Thought it might have been brake fluid but after getting under my car I seen the liquid wasn't even touching my caliper and it was dripping from the suspension, I had also noticed an Unusual squeak when driving over bumps and such, It was only one that was leaking but i replaced them all around with KYB's
post Mar 4, 2011 - 7:36 PM
zfjohnson07
Joined Apr 11, '09
so when you hit a tiny bump and your cd skips you need new struts lmao
post Mar 12, 2011 - 11:43 AM
block
Joined Jul 27, '06
From Soda
or that your cd player is tooooooo old and need an upgrade
post Mar 12, 2011 - 5:59 PM
zfjohnson07
Joined Apr 11, '09
Well its prob struts when I go over rail road tracks it hits
hard
post Mar 14, 2011 - 7:12 PM
xrav22
Joined Jul 24, '08
QUOTE (zfjohnson07 @ Mar 12, 2011 - 5:59 PM) *
hard
Now that I lowered the front I have to be carefull because it does bottom out again on big dips, but not on the freeway.
post Mar 15, 2011 - 7:22 PM
eboz74
Joined Dec 14, '10
From Lansing MI
i change mine once the ride gets way to bumpy when you get some make sure you get a lifetime warrenty....speaking of which has anyone ever used gibson struts? they're on sale at autozone
post Mar 17, 2011 - 7:23 PM
blu94gt
Joined Mar 23, '05
From Kansas City
I usually just replace when they have a little extra bounce, or if they're leaking. But I definitely wouldn't let them pass the 100k mark.
In auto-tech school we were taught that most struts' life begins to end around 50k miles. I've found it tends to vary from car to car. I've seen cars with less than 10k with leaking struts, and seen cars with over 100k that handle very well.
1999 Celica GT
post Mar 19, 2011 - 11:23 PM
Mycurse180
Joined Dec 23, '10
From PA, USA
My suspension makes a loud banging noise as I go over bumps, it appears to be coming from the back. The guy I bought it from said it needs strut top rubber bushing or something like that.
Any input?
post Mar 19, 2011 - 11:30 PM
When I decided that my need to lower was OVER 9000!!!!!!!!!! so I replaced my ~80k mile OEM stuffs with Sportline springs and KYB GR-2 struts.
'90 MX-5 Mariner Blue
'15 Optima Grey
'04 206 GTi silve
post Mar 22, 2011 - 7:04 PM
zfjohnson07
Joined Apr 11, '09
well i replaced my struts today, still riding hard on the passenger side, and when i slow down and press the brakes i can feel it jerk a lil. but when going fast it doesnt, i think i'll take it to a mechanic unless you got any ideas peeps
also before i changed it noticed the passenger side looks like it sits lower, so i was like oh yeah needs to be changed, when i changed it, it still sat low... alignment?? idk
This post has been edited by zfjohnson07: Mar 22, 2011 - 7:32 PM
Lo-Fi Version Time is now: August 29th, 2026 - 7:31 PM
