Feb 26, 2011 - 6:59 PM
Enthusiast Joined Feb 16, '11 From London Currently Offline Reputation: 0 (0%) |
Alright guys...
![]() I'm assuming this is a gen7 (seeing as the picture is stolen from 'new celica.org') I'm wondering if these are exactly the same on the gen 6? Does it have front and rear central jacking points? The reason I'm asking this is I'm getting a strange rubbing and creaking sound from the passenger side which is easily audible when setting off from a stand still and if changing into second at low revs, looks like the pads are actually touching the disc?? Here's a photo taken while the wheel is still on: ![]() Circled in red...the brake disc and pad are actually touching, there's still ability to spin the wheel freely (I jacked it up real quick yesterday to see what sound came back when spinning the wheel) but it does make a rubbing sound, area circled in blue...is that scoring or just signs of a used disc?. Still need confirmation on where I can jack/axle stand the car properly though! If anyone has any photo's I'd be dead grateful |
Feb 26, 2011 - 7:12 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 17, '10 From U.P. michigan GO STATE Currently Offline Reputation: 3 (100%) |
it is supposed to have a bit of resistance, if it spinns without any than your brakes need to be adjusted. atleast that is what i was told by all of the instructors at school. looks like you need new rotors and pads.. that scorring looks not so bad, i have seen much worse out on the roads.
![]() Celica: The name is derived from the Spanish word for "heavenly" or "celestial". Back-2-Back July COTM 15&16 |
Feb 26, 2011 - 7:13 PM
Ok cool, thanks for that! You think the weird creaking could be down to top mounts or something then?
Feb 26, 2011 - 8:02 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) |
I think the 6gen is a bit wider on the "axle stand" spots. When I jack the car up, from the front I use the cross member to jack and place the stands where the scissor jack goes, and as for the rear (being that i've only done that a few times) I look for the best spot and jack away. Again, using the spot where the scissor jack goes to place the stands.
Feb 26, 2011 - 10:12 PM
the creaking noise you are hearing may be what is common, what happens is when the lube on the back of the brake pads and the tabs wear away there will be a creaking noise, also sometimes when you used the brakes there may be a loud clicking noise, this would most likley be the pads being pushed into place on the caliper. common on some toyotas. at least thats what the TSB said on the computers at school.
Feb 27, 2011 - 12:02 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) |
how do you get rid of it? the sound screeching noise when braking
Feb 27, 2011 - 1:56 AM
take the calipers off and buy some siliglide, lube the metal brakets that hold the pads in place and lube the back side of the pads, it will most likley get rid of the noise. as for the screeching, discribe screeching.. does it sound more brakes related or a creeking noise when you use the brakes. if its screeching i would say replace the rotors and pads.
This post has been edited by 4-eyed-freek: Feb 27, 2011 - 1:57 AM -------------------- It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
Feb 27, 2011 - 6:18 AM
Thanks for the info, will get those bits checked out today
Feb 27, 2011 - 10:13 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) |
i know i posted these once before, but i can't find the thread:
floor jack ![]() scissor lift ![]() jack stands / hoist
This post has been edited by azian_advanced: Feb 27, 2011 - 10:14 PM -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Feb 28, 2011 - 10:11 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
Yeah as far as where to place jack stands and where to put the jack that what i do also, but my stands i cut slots in them with my grinder so the slots would fit firmly into them and hold in place
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
| Lo-Fi Version | Time is now: August 22nd, 2026 - 10:37 PM |
