> rod knock?
post Mar 1, 2011 - 11:09 AM
wvuguy
Joined Mar 1, '11
From Morgantown, WV
Hello every one,
I picked up a 1994 Toyota Celica with 137,000 miles for $300 yesterday. It has what seems to be a rod knock. The owner said it has only been driven 10 miles since it started knocking. She said the engine shut off in while driving and when she started up it started knocking. I have made a youtube video of the knock.
http://www.youtube.com/watch?v=z1CnaWB_8u4
I have heard that rod knock is loudest when you let off the gas. Thats what I am trying to do in the video but the noise goes away when I let it go. Also its pretty quite on idle and third gear. I am really hoping its the torque converter bolts. I took out spark plug wires one by one yesterday but the noise did not go away. Thanks.
post Mar 1, 2011 - 1:24 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
drain the oil and check for metallic residue.
**** Photobucket
post Mar 1, 2011 - 7:01 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
if its rod knock, plan on needing a new rod and have the crank turned. at worst, new crank. the cylinders should be just fine.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Mar 1, 2011 - 8:56 PM
wvuguy
Joined Mar 1, '11
From Morgantown, WV
I just drained the oil. Passed it through a screen but no signs of metal any where. However there is a greenlish layer on top when I shine light on it. Could it be a blown head gasket leading to a bad rod bearing?
post Mar 2, 2011 - 11:46 AM
wvuguy
Joined Mar 1, '11
From Morgantown, WV
I would think blown head gasket would cause milkshake like apearance in oil. Also coolant is not low. Could just be 18 months oil breaking down.
post Mar 2, 2011 - 12:36 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
correct. if coolant is in the oil it looks like chocolate milkshake. you might have caught the rod knock soon enough before the bearing chewes itself up. i still think pulling the engine and dissassembly is a must. dont take chances or you will be doing it all over again
post Mar 2, 2011 - 1:34 PM
wvuguy
Joined Mar 1, '11
From Morgantown, WV
Thanks guys. I am looking considering options of either putting a used low milage engine or rebuilding this one. Used 7AFE motors are available for pretty cheap.
post Mar 2, 2011 - 1:57 PM
wvuguy
Joined Mar 1, '11
From Morgantown, WV
Anyway the crankshaft can be pulled with engine in the car?
post Mar 3, 2011 - 2:05 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
not with the tranny in the car
flywheel needs to come off
post Mar 3, 2011 - 2:28 PM
wvuguy
Joined Mar 1, '11
From Morgantown, WV
I dropped the oil pan. Found silver metal powder at the bottom. The noise seemed to be coming from the first cylinder next to the transmission. By dropping the pan I can see only bearing caps of only two rods. How do I get to the rods towards the transmission? Thanks.
post Mar 3, 2011 - 5:08 PM
wvuguy
Joined Mar 1, '11
From Morgantown, WV
Nevermind, I figured out I need to remove #1 oil pan too. I came across a 4AFE motor at a local junk yard for $300. Its got about 70,000 miles on it and came out of a Geo Prizm?
Any one got a list of things that need to be disconnected before the engine an be pulled out? Smaay I saw your post about rebuilding the motor. Pretty awesome stuff. I noticed the transmission was attached to the motor when you put it back. Does it need to come out when you pull the motor? I have automatic.
post Mar 4, 2011 - 12:26 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
just start pullin stuff off that u see attaching the engine to other things of the car.
a 4afe will bolt up, but will run like ****, if at all, on the stock ecu, as its a 1.6, not a 1.8
post Mar 4, 2011 - 1:28 PM
wvuguy
Joined Mar 1, '11
From Morgantown, WV
stephen_lee, I have read some posts about 7AFE and 4AFE having the same horse power even though size is different. I understand I might have to out a different ECU if it doesn't run well. I am just looking for a practical car, don't care about power at this point.
post Mar 4, 2011 - 5:28 PM
bsamps4
Joined May 16, '10
From Raleigh
First question....how much would that junk yard motor cost? Second question....why not just rebuild it? Shouldn't be too expensive.
post Mar 4, 2011 - 5:54 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
4afe 105 HP, 7afe 110 HP
junkyards will cost 300-500$ with unknown condition
rebuilds will cost ~1200-1500
theres more than just swapping out ecus. its basically the same swap as a 7afe to 4age.
post Mar 5, 2011 - 8:03 PM
wvuguy
Joined Mar 1, '11
From Morgantown, WV
Oops I meant significant difference in horse power. From searching the forum, it seems like 4AFE is pretty much a straight drop without any mods needed. However for 4AGE, new ECU, wiring and throttle cable is needed. I want to keep the swap as simple as possible and get the car on the road. Don't care too much about some loss of power.
http://www.6gc.net/forums/index.php?showto...815&hl=4afe
http://www.6gc.net/forums/index.php?showtopic=43401
http://www.6gc.net/forums/index.php?showto...708&hl=4afe
http://www.6gc.net/forums/index.php?showto...028&hl=4afe
post Mar 5, 2011 - 8:30 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
HP is not the disparity between the two, its the distribution of torque across the rpm band.
post Mar 6, 2011 - 7:53 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (stephen_lee @ Mar 4, 2011 - 2:54 PM) *
rebuild will not cost that much. if you do all the work yourself, it can be done for about 500 bucks. cheaply. about 800 if you replace everything like in my guide
post Mar 6, 2011 - 9:42 PM
wvuguy
Joined Mar 1, '11
From Morgantown, WV
Bitter, I understand what you are saying but since this car has auto trans I am not sure its worth it.
Smaay, I have seen your thread butI have no experience building motors and I am not sure I can do that.
I finally dropped the no #1 oil pan today and there is a big groove in the oil pan from the #1 rod bearing cap hitting the oil pan. Cap did not feel loose though. Thats what all the metal power was from that I noticed in the oil pan. So I am guessing the engine is toast?
This post has been edited by wvuguy: Mar 7, 2011 - 9:53 AM
post Mar 7, 2011 - 2:24 PM
wvuguy
Joined Mar 1, '11
From Morgantown, WV
Well I looked at the some of the pictures on this forum and it seems like most 4AFE oil pans have this groove. Not sure there is anything worst with mine.
https://picasaweb.google.com/usmanwvu/Celic...411355877793186
Lo-Fi Version Time is now: June 24th, 2026 - 10:47 AM
