> rod knock?
post Mar 1, 2011 - 11:09 AM
wvuguy
Joined Mar 1, '11
From Morgantown, WV
Hello every one,
I picked up a 1994 Toyota Celica with 137,000 miles for $300 yesterday. It has what seems to be a rod knock. The owner said it has only been driven 10 miles since it started knocking. She said the engine shut off in while driving and when she started up it started knocking. I have made a youtube video of the knock.
http://www.youtube.com/watch?v=z1CnaWB_8u4
I have heard that rod knock is loudest when you let off the gas. Thats what I am trying to do in the video but the noise goes away when I let it go. Also its pretty quite on idle and third gear. I am really hoping its the torque converter bolts. I took out spark plug wires one by one yesterday but the noise did not go away. Thanks.
- wvuguy   rod knock?   Mar 1, 2011 - 11:09 AM
- - 95CelicaST   drain the oil and check for metallic residue.   Mar 1, 2011 - 1:24 PM
- - Smaay   if its rod knock, plan on needing a new rod and ha...   Mar 1, 2011 - 7:01 PM
- - wvuguy   I just drained the oil. Passed it through a screen...   Mar 1, 2011 - 8:56 PM
- - wvuguy   I would think blown head gasket would cause milksh...   Mar 2, 2011 - 11:46 AM
- - Smaay   correct. if coolant is in the oil it looks like ch...   Mar 2, 2011 - 12:36 PM
- - wvuguy   Thanks guys. I am looking considering options of e...   Mar 2, 2011 - 1:34 PM
- - wvuguy   Anyway the crankshaft can be pulled with engine in...   Mar 2, 2011 - 1:57 PM
- - stephen_lee   not with the tranny in the car flywheel needs to ...   Mar 3, 2011 - 2:05 PM
- - wvuguy   I dropped the oil pan. Found silver metal powder a...   Mar 3, 2011 - 2:28 PM
- - wvuguy   Nevermind, I figured out I need to remove #1 oil p...   Mar 3, 2011 - 5:08 PM
- - stephen_lee   just start pullin stuff off that u see attaching t...   Mar 4, 2011 - 12:26 PM
- - wvuguy   stephen_lee, I have read some posts about 7AFE and...   Mar 4, 2011 - 1:28 PM
- - bsamps4   First question....how much would that junk yard mo...   Mar 4, 2011 - 5:28 PM
- - stephen_lee   4afe 105 HP, 7afe 110 HP junkyards will cost 300-...   Mar 4, 2011 - 5:54 PM
|- - Smaay   QUOTE (stephen_lee @ Mar 4, 2011 - 2...   Mar 6, 2011 - 7:53 PM
|- - stephen_lee   QUOTE (Smaay @ Mar 6, 2011 - 6:53 PM...   Mar 8, 2011 - 12:53 PM
- - wvuguy   Oops I meant significant difference in horse power...   Mar 5, 2011 - 8:03 PM
- - Bitter   HP is not the disparity between the two, its the d...   Mar 5, 2011 - 8:30 PM
- - wvuguy   Bitter, I understand what you are saying but since...   Mar 6, 2011 - 9:42 PM
- - wvuguy   Well I looked at the some of the pictures on this ...   Mar 7, 2011 - 2:24 PM
- - wvuguy   Found out that two rod bearing cops towards the tr...   Mar 7, 2011 - 7:58 PM
- - wvuguy   Can any please confirm that the rod bearing cap bo...   Mar 8, 2011 - 1:18 PM
- - stephen_lee   my 7a had a 12mm 12pt socket. instead of the typic...   Mar 8, 2011 - 1:21 PM
- - wvuguy   Thats what it is. Thanks.   Mar 8, 2011 - 2:20 PM
- - wvuguy   Finally got the bearing cap off. The bearing was a...   Mar 8, 2011 - 8:18 PM
- - stephen_lee   save the block && rebuild it. i like to ke...   Mar 9, 2011 - 7:21 PM
Lo-Fi Version Time is now: March 25th, 2026 - 3:01 PM
