Mar 11, 2011 - 6:55 AM
Enthusiast ![]() Joined Jan 1, '11 From uk Currently Offline Reputation: 3 (100%) |
hello does anyone know where to get header / manifold for gen6 2.0 gt 3sge ,(new one) but not so expensive like hks or fujitsubo
This post has been edited by smoog83: Mar 11, 2011 - 7:02 AM |
Mar 11, 2011 - 2:44 PM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
had this question asked recently, will find my answer.
The factory extractor type manifolds fitted the 3S-GE and BEAMS 3S-GE are very good. Toyota put some effort into the design and flow of these. So any gains, are not going to be as much. QUOTE (Edophus) rusty is right, there isnt a lot wrong with the stock extractors... the welds tend to be tack welds on the outside and welded on the inside, if you reweld the manifold so the welds are on the outside of the pipe, take a dremel and grind out the garbage on the inside of the pipe, so far i've found the manifolds to be really sloppy here, the design is fundementally fine, but the execution is poor. This isnt a power adder as such but will free up the engine at high revs I dont know if you've read it but this thread has a lot of good infomation regarding the 3S-GE engines. -------------------- |
Mar 11, 2011 - 4:13 PM
thnx ,i wsnt really after performance ,as i know toyota done good job ,its more cosmetic reason at this stage .nd to clean ,polish headers its a nightmare ,better buy new one ,its nice to have shiny engine bay .well one day i might go mad nd ill buy hks
| Lo-Fi Version | Time is now: June 25th, 2026 - 7:40 PM |
