Mar 11, 2011 - 7:51 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
http://www.youtube.com/watch?v=kYbohL72m0I
The first couple seconds is me showing where the noise is generally coming from, but you can hear it as well. It's a popping noise. Then I put the mic closer to hear it louder. What could that be? -------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
Mar 13, 2011 - 2:53 AM
Anybody have an idea?
Mar 17, 2011 - 8:42 PM
No one?? lol
Mar 17, 2011 - 11:06 PM
Enthusiast ![]() ![]() Joined Jun 5, '07 From Santa Maria Currently Offline Reputation: 1 (100%) |
sounds like your timing belt cover is loose. Apply pressure to the cover and see if the sound goes away.
Mar 19, 2011 - 11:09 AM
Enthusiast ![]() ![]() Joined Jul 24, '08 From Canoga Park CA. Currently Offline Reputation: 0 (0%) |
Mar 19, 2011 - 11:40 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 27, '06 From Soda Currently Offline Reputation: 9 (91%) |
did you replace your waterpump?
Mar 19, 2011 - 3:48 PM
did you replace your waterpump? Yeah. I did timing belt and water pump about 3k miles ago. Another thing, this noise only comes out when I'm at nominal temperature. -------------------- taking too long to mod since '09
Mar 19, 2011 - 4:30 PM
Its the trans coupler inverter shaft bearings behind the oil pump, for sure.
Mar 19, 2011 - 5:28 PM
Its the trans coupler inverter shaft bearings behind the oil pump, for sure. All I thought when I read that was "so it's the flux capacitor..." lol What exactly are those? -------------------- taking too long to mod since '09
Mar 19, 2011 - 6:48 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 18, '08 From Houston Currently Offline Reputation: 7 (100%) |
Belt dont have no knicks does it?
and only a Normal operating temp? It's for sure comming outta the belt area? could be some of the componet bearings. -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Mar 19, 2011 - 8:01 PM
and only a Normal operating temp? It's for sure comming outta the belt area? could be some of the componet bearings. Seems likely... Previous owners sound like they didn't know what "maintenance" meant. I'm just fixing things as they break. The belts are good. And yeah, it's definitely coming from that area and only at nominal temp, which means about 750-900rpm -------------------- taking too long to mod since '09
Mar 19, 2011 - 9:06 PM
just for giggles...get it warmed up, take the accessory belts off (I know, a pain) and then run the engine. If it still makes the noise it could be a timing belt idler or tensioner pulley bearing making noise. Sometimes they only make noise at a specific RPM or at high speeds the belt has enough force to make them spin.
Mar 19, 2011 - 10:09 PM
^^^ got a point- but STOOOOPIDLY unlikely. not to be confused with impossible. We've all seen stranger.... lol
and only a Normal operating temp? It's for sure comming outta the belt area? could be some of the componet bearings. Seems likely... Previous owners sound like they didn't know what "maintenance" meant. I'm just fixing things as they break. The belts are good. And yeah, it's definitely coming from that area and only at nominal temp, which means about 750-900rpm Try to zero in to a certin part. if you can find it down to be the alt/PS pump/ect. then you got a sold ground to stand on. ANY Click nose comes with a Vibration. Just a first though. (it's how i do it) worse case- Gimmie call. You got my new number still, yeah? I'll help you out man. -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Mar 20, 2011 - 2:36 AM
worse case- Gimmie call. You got my new number still, yeah? I'll help you out man. Nah, I don't have your number. Facebooks! But yeah, I'll warm her up soon and give it another listen. -------------------- taking too long to mod since '09
Mar 20, 2011 - 9:43 AM
not that unlikely, but somewhat unlikely for that kind of knocky noise. Not impossible though....
| Lo-Fi Version | Time is now: June 22nd, 2026 - 10:09 PM |
