> just to make sure this spacers will fit good?, want to double check
post Mar 20, 2011 - 1:57 AM
diegohiga
Joined May 4, '09
From coral springs florida US
Bolt Pattern: 5x100... good
Center Bore: 54.1....?
Thread Type: 12X1.5.... good
Spacer Thickness: 25MM.... too wide?
ebay link... or i shouldnt buy it from ebay?
http://cgi.ebay.com/ebaymotors/Toyota-Celi...=item20b41836a6
This post has been edited by diegohiga: Mar 20, 2011 - 1:58 AM
post Mar 20, 2011 - 4:19 PM
Lone_Wolf
Joined Apr 22, '09
From Work
If your gonna buy from ebay buy the right ones with the extended studs.
http://cgi.ebay.com/ebaymotors/H-R-25MM-WH...sQ5fAccessories
**If you can read this you are too close**
post Mar 20, 2011 - 8:46 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
25mm should be good. i have 15mm and i had to circumcise my lugs because they protrude too far and hit the wheels
you may have to roll your front guards to fit 25mm in front btw. it should be pretty flush in the rear though
This post has been edited by delusionz: Mar 20, 2011 - 10:50 PM
Mike W
269awhp / 273ft-lbs
Lo-Fi Version Time is now: August 29th, 2026 - 8:03 AM
