Mar 20, 2011 - 3:19 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
Curious as to if i can use a harness from and obd1 harness for my car that is obd2 when i swap so the car is not down as long, so are they the same from a 94 to a 96?
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
Mar 21, 2011 - 6:39 AM
Bump for help, don't want to waste my money
Mar 21, 2011 - 7:14 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 4, '06 From Chicagoland Currently Offline Reputation: 9 (100%) |
I don't think so. IIRC, the OBDII harness has a cam/crank angle sensors while the OBDI harness just has the cam position sensor integrated into the distributor. Without the crank angle sensor, you will throw a CEL. There might be other differences, but I definitely know that.
-------------------- ~bloodMoney
Mar 21, 2011 - 7:22 AM
there are harness diffrences between the 2.
Mar 21, 2011 - 9:17 AM
the harness is going to be used for a 3s swap, so im not sure if the CAS will matter or not
Mar 21, 2011 - 9:46 AM
send a PM to Dr Tweak, he will know the answer
Mar 22, 2011 - 7:39 AM
if your doing a 3rd gen swap, it dont matter, you dont use the 5s harness at all. (at least i dont when i do them..cant speak for anyone else.)
Mar 22, 2011 - 9:52 PM
Yeah figured that out, talked to tweak and he said the same thing about not needing the orginal harness
Yeah figured that out, talked to tweak and he said the same thing about not needing the orginal harness -------------------- 1996 Toyota Celica Project Mean Green
| Lo-Fi Version | Time is now: August 31st, 2026 - 1:56 AM |
