Mar 28, 2011 - 12:07 AM
Enthusiast ![]() Joined Jan 10, '11 From Trail BC Currently Offline Reputation: 1 (100%) |
Now that you said that Brenton, I did mount a wire behind the intake manifold, on a 10mm bolt the wire had an end that excepted that bolt, n screwed it tight to back of manifold. From the harness Ok just tested coil with battery + - and had a very very small spark on coil wire ( discharge ) end, to screwdriver, is this spark supposed to be big n bold, or barely able to see it????? Cause that's what it was...really had to look for the spark???? K man, I am gettin one tomorrow.....keep my fingers crossed, the scary thing is, if this doesn't work, I don't know what else it could be???? Just checked power to ECU, and it lights up like a Christmas tree...definitely power to ECU. |
Mar 28, 2011 - 1:44 AM
Now that you said that Brenton, I did mount a wire behind the intake manifold, on a 10mm bolt the wire had an end that excepted that bolt, n screwed it tight to back of manifold. From the harness Ok just tested coil with battery + - and had a very very small spark on coil wire ( discharge ) end, to screwdriver, is this spark supposed to be big n bold, or barely able to see it????? Cause that's what it was...really had to look for the spark???? K man, I am gettin one tomorrow.....keep my fingers crossed, the scary thing is, if this doesn't work, I don't know what else it could be???? Just checked power to ECU, and it lights up like a Christmas tree...definitely power to ECU. Do you still think it's my coil when I'm not getting a pulse signal when cranking, |
Mar 28, 2011 - 9:03 AM
Enthusiast ![]() ![]() Joined Feb 28, '11 Currently Offline Reputation: 5 (100%) |
Now that you said that Brenton, I did mount a wire behind the intake manifold, on a 10mm bolt the wire had an end that excepted that bolt, n screwed it tight to back of manifold. From the harness Ok just tested coil with battery + - and had a very very small spark on coil wire ( discharge ) end, to screwdriver, is this spark supposed to be big n bold, or barely able to see it????? Cause that's what it was...really had to look for the spark???? K man, I am gettin one tomorrow.....keep my fingers crossed, the scary thing is, if this doesn't work, I don't know what else it could be???? Just checked power to ECU, and it lights up like a Christmas tree...definitely power to ECU. Do you still think it's my coil when I'm not getting a pulse signal when cranking, ................. is your car turning over ? |
Mar 28, 2011 - 11:04 AM
Now that you said that Brenton, I did mount a wire behind the intake manifold, on a 10mm bolt the wire had an end that excepted that bolt, n screwed it tight to back of manifold. From the harness Ok just tested coil with battery + - and had a very very small spark on coil wire ( discharge ) end, to screwdriver, is this spark supposed to be big n bold, or barely able to see it????? Cause that's what it was...really had to look for the spark???? K man, I am gettin one tomorrow.....keep my fingers crossed, the scary thing is, if this doesn't work, I don't know what else it could be???? Just checked power to ECU, and it lights up like a Christmas tree...definitely power to ECU. Do you still think it's my coil when I'm not getting a pulse signal when cranking, ................. is your car turning over ? yes, my car cranks very strong, and i have two igniters, i have tried both....nothing, had a friend check relays when turn key on, and both EFI and ST relay click, but even if my timing is off, wouldnt i still see a spark?? |
Mar 28, 2011 - 11:10 AM
Mar 28, 2011 - 1:40 PM
Well,'just finished installing new coil.....tried cranking again n nothin......this reappoint SUCKS!!
Mar 28, 2011 - 1:47 PM
Now that you said that Brenton, I did mount a wire behind the intake manifold, on a 10mm bolt the wire had an end that excepted that bolt, n screwed it tight to back of manifold. From the harness Ok just tested coil with battery + - and had a very very small spark on coil wire ( discharge ) end, to screwdriver, is this spark supposed to be big n bold, or barely able to see it????? Cause that's what it was...really had to look for the spark???? K man, I am gettin one tomorrow.....keep my fingers crossed, the scary thing is, if this doesn't work, I don't know what else it could be???? Just checked power to ECU, and it lights up like a Christmas tree...definitely power to ECU. Do you still think it's my coil when I'm not getting a pulse signal when cranking, ................. is your car turning over ? yes, my car cranks very strong, and i have two igniters, i have tried both....nothing, had a friend check relays when turn key on, and both EFI and ST relay click, but even if my timing is off, wouldnt i still see a spark?? yes you would see a spark even if the timing is off umm man the only thing i could think off is the ecu or tweaksss wires but i really dont think its the wires but u never know how do u know its not e=gettin a spark did u stick a screw driver in there and let it light u up lol i kno it sound crazy but thats what i do lol call tweak if i was u i would send him my ecu and the wires let him go over it and make sure its good there find the ground to the ecu like u did the power see if your ecu is getting ground i think u are having a ground problem if i was near u i kno i could fix your problem but not being around the car is kind of hard lol i know how to make a car start when its not getting a spark but like i said im not near u so lol i have to go off your info does all your dash lights come on then u turn the key i kno this sound crazy but sometimes these cars get a short mine had this problem the check engine light wont come on when u turn the key that means some where those wires i was tellin u about has a short your car will turn over but wont start its a purple wire a pink wire and the other one is either white black or brown i cant remember but we had to e run that wire because it was trippin i know the prolem u are having because my car use to do it |
| Lo-Fi Version | Time is now: August 30th, 2026 - 3:22 PM |
