Mar 30, 2011 - 5:58 AM
![]() Enthusiast ![]() ![]() ![]() Joined Nov 18, '10 From montreal Currently Offline Reputation: 0 (0%) |
i have some question, plz can someone answer it ?
those should be easy to anwser for any who did the swap so question#1 where does this fuel line goes ? ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us question#2 where u plug this plastic bottle (the bottom of it) ![]() Uploaded with ImageShack.us question #3 where do i plug that line ? ![]() Uploaded with ImageShack.us question #4 how u setup this to this to this ?? plz ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us question #5 where is the plug for this (lead prestone to the chargercooler) smic) ![]() ![]() question# 6 where does that one goes ? ![]() Uploaded with ImageShack.us questin #7 and finally this one , i dont know where it goes ? ![]() Uploaded with ImageShack.us question#8 where this 2 plus goes ?? ![]() Uploaded with ImageShack.us thank for any help This post has been edited by Needles: May 10, 2011 - 2:53 PM |
Needles need help finishin 3sgte install Mar 30, 2011 - 5:58 AM
presure2 1 looks like the fuel return line
2 is an overflow... Mar 30, 2011 - 6:40 AM
Needles thanks a lot presure2, im going back to work now Mar 30, 2011 - 6:52 AM
presure2 looking again, #6 looks like it could be the Ic le... Mar 30, 2011 - 9:23 AM
Needles ok, i have setup the water inc pump, now i will pl... Mar 30, 2011 - 9:56 AM
mak5603 Glad you posted this, and glad Manny is such a 3s ... Mar 30, 2011 - 12:27 PM
nsxtypeR No 3 goes directly into the intake hose between ai... Mar 30, 2011 - 12:47 PM
Needles after i plugged all back in the harness and finish... Apr 4, 2011 - 8:10 PM
presure2 QUOTE (Needles @ Apr 4, 2011 - 9:10 ... Apr 10, 2011 - 10:52 AM
Needles solve Apr 10, 2011 - 10:22 AM
Needles now i heard clic sound when i try starting the eng... Apr 10, 2011 - 11:48 AM
Needles ok interior plug done just like u do in ur progree... Apr 10, 2011 - 12:40 PM
presure2 QUOTE (Needles @ Apr 10, 2011 - 1:40... Apr 10, 2011 - 5:16 PM
delusionz You need to look at a GT4 build thread, those thin... Apr 10, 2011 - 5:33 PM
Needles i tried to look what does go to the negative pole ... Apr 12, 2011 - 5:38 PM
Needles hello again !
so im in triyng to make my ca... Apr 14, 2011 - 2:46 PM
mkernz22 that wiring is a MESS! (most likely your probl... Apr 14, 2011 - 2:58 PM
Needles QUOTE (mkernz22 @ Apr 14, 2011 - 2:5... Apr 14, 2011 - 3:04 PM
presure2 that switch is aftermarket, prolly for some type o... Apr 14, 2011 - 5:08 PM
Needles QUOTE (presure2 @ Apr 14, 2011 - 6:0... Apr 15, 2011 - 9:55 AM
Defgeph Charge your battery and try again. If that doesn... Apr 14, 2011 - 7:03 PM
Needles i found my mistake !! the plug for positiv... Apr 15, 2011 - 12:03 PM
delusionz ????
Did you try to jump start it? The big smoke ... Apr 16, 2011 - 4:55 PM
Needles yo its there lol, its extend whit orange black wir... Apr 17, 2011 - 12:37 AM
Needles after i did a nice ground setup, 4gauge to tranny ... Apr 18, 2011 - 6:03 PM
delusionz Check your battery? Can you hear a click from the ... Apr 18, 2011 - 11:54 PM
Needles Starter Does not Operate
When your starter does n... Apr 19, 2011 - 5:46 AM
delusionz I think I can see what your problem is, I think yo... Apr 19, 2011 - 6:54 AM
Needles QUOTE (delusionz @ Apr 19, 2011 - 7... May 7, 2011 - 10:29 PM
Needles i had try to boost it direct on the starter and...... Apr 20, 2011 - 3:05 PM
Needles omg problem solved !
my ea1 plug was bad conn... Apr 27, 2011 - 1:01 PM
Needles since i dont have a clip, i dont know where the fu... Apr 27, 2011 - 2:26 PM
Needles im sorry my last post a bit confusing.....
i ju... Apr 27, 2011 - 10:05 PM
Needles that ok i found it
from EA1 there are 4 wires t... Apr 28, 2011 - 8:00 AM
Needles its start crank over !!! wooo
whit al... May 9, 2011 - 4:12 PM![]() ![]() |
| Lo-Fi Version | Time is now: July 11th, 2026 - 11:28 AM |
