> need help finishin 3sgte install, engine started !!
post Mar 30, 2011 - 5:58 AM
Needles
Joined Nov 18, '10
From montreal
i have some question, plz can someone answer it ?
those should be easy to anwser for any who did the swap
question#1 where does this fuel line goes ?
Uploaded with ImageShack.us
question#2 where u plug this plastic bottle (the bottom of it)
question #3 where do i plug that line ?
question #4 how u setup this to this to this ?? plz
question #5 where is the plug for this (lead prestone to the chargercooler) smic)
question# 6
where does that one goes ?
questin #7 and finally this one , i dont know where it goes ?
question#8 where this 2 plus goes ??
This post has been edited by Needles: May 10, 2011 - 2:53 PM
- Needles   need help finishin 3sgte install   Mar 30, 2011 - 5:58 AM
- - presure2   1 looks like the fuel return line 2 is an overflow...   Mar 30, 2011 - 6:40 AM
- - Needles   thanks a lot presure2, im going back to work now   Mar 30, 2011 - 6:52 AM
- - presure2   looking again, #6 looks like it could be the Ic le...   Mar 30, 2011 - 9:23 AM
- - Needles   ok, i have setup the water inc pump, now i will pl...   Mar 30, 2011 - 9:56 AM
- - mak5603   Glad you posted this, and glad Manny is such a 3s ...   Mar 30, 2011 - 12:27 PM
- - nsxtypeR   No 3 goes directly into the intake hose between ai...   Mar 30, 2011 - 12:47 PM
- - Needles   after i plugged all back in the harness and finish...   Apr 4, 2011 - 8:10 PM
|- - presure2   QUOTE (Needles @ Apr 4, 2011 - 9:10 ...   Apr 10, 2011 - 10:52 AM
- - Needles   solve   Apr 10, 2011 - 10:22 AM
- - Needles   now i heard clic sound when i try starting the eng...   Apr 10, 2011 - 11:48 AM
- - Needles   ok interior plug done just like u do in ur progree...   Apr 10, 2011 - 12:40 PM
|- - presure2   QUOTE (Needles @ Apr 10, 2011 - 1:40...   Apr 10, 2011 - 5:16 PM
- - delusionz   You need to look at a GT4 build thread, those thin...   Apr 10, 2011 - 5:33 PM
- - Needles   i tried to look what does go to the negative pole ...   Apr 12, 2011 - 5:38 PM
- - Needles   hello again ! so im in triyng to make my ca...   Apr 14, 2011 - 2:46 PM
- - mkernz22   that wiring is a MESS! (most likely your probl...   Apr 14, 2011 - 2:58 PM
|- - Needles   QUOTE (mkernz22 @ Apr 14, 2011 - 2:5...   Apr 14, 2011 - 3:04 PM
- - presure2   that switch is aftermarket, prolly for some type o...   Apr 14, 2011 - 5:08 PM
|- - Needles   QUOTE (presure2 @ Apr 14, 2011 - 6:0...   Apr 15, 2011 - 9:55 AM
- - Defgeph   Charge your battery and try again. If that doesn...   Apr 14, 2011 - 7:03 PM
- - Needles   i found my mistake !! the plug for positiv...   Apr 15, 2011 - 12:03 PM
- - delusionz   ???? Did you try to jump start it? The big smoke ...   Apr 16, 2011 - 4:55 PM
- - Needles   yo its there lol, its extend whit orange black wir...   Apr 17, 2011 - 12:37 AM
- - Needles   after i did a nice ground setup, 4gauge to tranny ...   Apr 18, 2011 - 6:03 PM
- - delusionz   Check your battery? Can you hear a click from the ...   Apr 18, 2011 - 11:54 PM
- - Needles   Starter Does not Operate When your starter does n...   Apr 19, 2011 - 5:46 AM
- - delusionz   I think I can see what your problem is, I think yo...   Apr 19, 2011 - 6:54 AM
|- - Needles   QUOTE (delusionz @ Apr 19, 2011 - 7...   May 7, 2011 - 10:29 PM
- - Needles   i had try to boost it direct on the starter and......   Apr 20, 2011 - 3:05 PM
- - Needles   omg problem solved ! my ea1 plug was bad conn...   Apr 27, 2011 - 1:01 PM
- - Needles   since i dont have a clip, i dont know where the fu...   Apr 27, 2011 - 2:26 PM
- - Needles   im sorry my last post a bit confusing..... i ju...   Apr 27, 2011 - 10:05 PM
- - Needles   that ok i found it from EA1 there are 4 wires t...   Apr 28, 2011 - 8:00 AM
- - Needles   its start crank over !!! wooo whit al...   May 9, 2011 - 4:12 PM
Lo-Fi Version Time is now: August 28th, 2026 - 9:01 PM
