23 Pages V  < 1 2 3 4 > »
Closed TopicStart new topic
> FS : Spree LED dash kits for all gen 6 Celicas, Covers the whole dash inc. clock not just the speedo!
post Apr 4, 2011 - 5:01 PM
Spree
Joined Mar 25, '11
From West London
QUOTE (lynxiesz @ Apr 4, 2011 - 5:47 PM) *
Good work Julian! payment sent! =)
Thanks mate. :-)
I will be sending all the kits that have been ordered so far out over the next couple of days, I may even get them all out tomorrow.
www.SpreeLED.com Facebook Youtube
SMD LED CONVERSIONS FOR ALL TOYOTA CELICA GEN 6 - DASH - COURTESY LIGHTS - SIDELIGHTS - LICENCE PLATE BULBS - BRAKE LIGHTS
post Apr 4, 2011 - 5:42 PM
nammer
Joined Aug 22, '07
From Burnaby, British Columbia, Canada
PM'd paypal address request
post Apr 5, 2011 - 4:30 PM
Spree
Joined Mar 25, '11
From West London
QUOTE (nammer @ Apr 4, 2011 - 6:42 PM) *
post Apr 5, 2011 - 4:37 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
Have any kits been shipped out yet?
post Apr 6, 2011 - 10:46 AM
Spree
Joined Mar 25, '11
From West London
QUOTE (KAOS @ Apr 5, 2011 - 5:37 PM) *
All kits ordered so far have now been posted. :-)
post Apr 10, 2011 - 5:10 AM
Spree
Joined Mar 25, '11
From West London
The kits will be arriving this week guys, let me know how you get on and please post pics on the forum of the finished results. :-)
post Apr 10, 2011 - 12:08 PM
lynxiesz
Joined Feb 9, '09
From Toronto
post Apr 10, 2011 - 12:57 PM
bizzerk
Joined Nov 6, '07
From seattle
QUOTE (Spree @ Apr 3, 2011 - 12:22 PM) *
QUOTE (bizzerk @ Apr 3, 2011 - 11:56 AM) *
Do you have pdf files for how to install the guage cluster l.e.d.s?
Hi,
I dont have any pdf files as my instructions are sold with my kits in the form of a booklet and my led's also have a simple but important difference to them that gives the instrument cluster a much better light spread and illuminates the needles properly.
I can give you a quick breakdown of how to simply swap the bulbs in the instrument cluster over though, its very easy. You will need a long phillips head screwdriver and a stubby one. :-) :
1. Adjust steering wheel to lowest position.
2. Grab plastic trim behind steering wheel and pull it off with a hand on each side.
3. Locate and remove the four screws holding the black plastic shroud to remove it.
4. Locate and remove the four screws securing the clocks.
5. Release the electrical connectors behind the instrument cluster
6. Install the LED's into the three largest green bulb holders by twisting them out and swapping the bulbs.
7. Make sure you test for correct polarity before refitting by plugging everything back in and switching the lights on, whatever one is not working needs to be removed, rotated 90 degrees, refitted and retested.
8. Refit everything as per reversal of removal in true Haynes style.
9. Sit in your car and gaze, awestruck at your accomplishment for a while but then realise that you would like the rest of your dash to match your speedo, that you may of even possibly bought the wrong LED's and that you now actually crave a full kit from Spree lol
omg haha I just reread my post, I entirely did not meant to say gauge cluster, but climate control instead xDDDDD. The climate control LED should be relatively easy to install? I'll be ordering soon.
post Apr 10, 2011 - 1:19 PM
Spree
Joined Mar 25, '11
From West London
Lol no worries.
The climate control on jap cars is pretty easy bit the hvac unit on the US cars is a pain in the neck due to the cables that have to be disconnected and the fact that the unit itself is more complex. I did manage to fit a kit without disconnecting the cables but it was still a pain. Its still doable though and all it means is that it takes longer to do. But we are still talking four hours max if you are really taking your time. I did it in the dark!
post Apr 11, 2011 - 1:31 PM
Spree
Joined Mar 25, '11
From West London
post Apr 11, 2011 - 1:33 PM
KAOS
Joined Apr 18, '06
QUOTE (Spree @ Apr 10, 2011 - 12:19 PM) *
I love doing it in the dark...
This post has been edited by KAOS: Apr 11, 2011 - 1:34 PM
post Apr 11, 2011 - 1:46 PM
Spree
Joined Mar 25, '11
From West London
QUOTE (KAOS @ Apr 11, 2011 - 2:33 PM) *
I set myself up for that one!
post Apr 12, 2011 - 7:50 PM
gt4st205
Joined Jan 2, '11
From Misawa, Japan
I'm going to order soon, but I wanted to know, is purple an option?
This post has been edited by gt4st205: Apr 12, 2011 - 7:51 PM
post Apr 12, 2011 - 7:54 PM
question, i just realized the us spec has 4 lights. three can be seen here. i just added more to create more light dispersion
but the fourth one is located in the rear window defogging, that will light up green...
can you supply the 4th one...
This post has been edited by njccmd2002: Apr 12, 2011 - 7:55 PM
post Apr 13, 2011 - 5:10 AM
Spree
Joined Mar 25, '11
From West London
QUOTE (njccmd2002 @ Apr 12, 2011 - 8:54 PM) *
Hi,
Just to confirm that the backlighting is provided by three removable bulbs as you have shown in your picture. These are easily changed using my kit.
The button indication LED's such as the one found in the rear window demister button need to be unsoldered and the new LED's need to be resoldered in.
I do not provide these as my kit is intended as a DIY kit without the need to be any good at solderering. I feel that changing the backlighting colour gives a very satisfying result that will suit most people but I do understand that some will want to also change the button colour. I also do not have time to do this service for people.
In the UK I recommend these people to a guy on the UK forums who will do this as a service if you send him your unit for £20 ($32 ish) but I dont know about over your way. I can contact him for you though if you are really desperate? He does really good work.
Julian.
post Apr 13, 2011 - 3:09 PM
rave2n
Joined May 29, '09
From Gainesville, FL
QUOTE (Spree @ Apr 13, 2011 - 5:10 AM) *
Hi,
Julian.
Someone not across the pond should be able to accomplish this.
Hell if no one stands up, i'll do it =P
post Apr 13, 2011 - 3:16 PM
KAOS
Joined Apr 18, '06
Julian;
I was just looking through a kit you send to Kellen awhile ago; whats this bulb for?
I went through your instructions, briefly mind you, but didn't see where this LED was used...?
post Apr 13, 2011 - 3:32 PM
Spree
Joined Mar 25, '11
From West London
QUOTE (KAOS @ Apr 13, 2011 - 4:16 PM) *
Julian;
That will be the one for the Ignition ring if yours lights up. If not then its a spare!
post Apr 13, 2011 - 3:33 PM
KAOS
Joined Apr 18, '06
Aha!
I thought the ignition ring had to be wired up like the heater controls (where you match the LED wiring to the panel)... kewl!
Thanks!
post Apr 13, 2011 - 3:57 PM
Hi,
Julian.
ok cool, can you provide the extra led if i get your kit, i can solder it , piece of cake. I want to go to a different color, and have a new board that i do not want to solder. just the small one..
do you have this kit in orange, like the 2000+ newer celicas...
Lo-Fi Version Time is now: June 22nd, 2026 - 1:42 PM
