Apr 4, 2011 - 12:06 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) |
after parking the car on a drive way (which is perfectly flat), i notice my car tilting more towards the driver side...is this normal? i check and measure front tire gap to fenders going all the way down on all sides and they're the same, yet it still tilts.
![]() *i had an alignment done to it already. This post has been edited by chacha: Apr 4, 2011 - 2:45 PM |
chacha Anyone have this problem tilting problem? Apr 4, 2011 - 12:06 PM
rave2n Driveway not as flat as imagined?
Looks like its ... Apr 4, 2011 - 3:46 PM
chacha i gotta figure out...i just wanted to see if anyon... Apr 4, 2011 - 4:59 PM
mkernz22 your car is perfectly fine. your garage is the pro... Apr 4, 2011 - 5:40 PM
chacha hahaha...thanks mkern
i tried parking on a flat, ... Apr 4, 2011 - 6:35 PM
schmooot put a level on the spoiler Apr 5, 2011 - 8:13 PM
richee3 If your car does tilt, I suspect bad struts or spr... Apr 5, 2011 - 8:24 PM
trdproven QUOTE (richee3 @ Apr 6, 2011 - 11:24... Apr 9, 2011 - 6:19 AM
chacha yeah..from bottom fender to the ground...both fron... Apr 6, 2011 - 12:38 PM
SupraKid Flat concrete outdoor pads like that are usually t... Apr 6, 2011 - 12:46 PM
whatthe On another note, heaps nice trd wing Apr 6, 2011 - 1:45 PM
808celica QUOTE (chacha @ Apr 4, 2011 - 7:06 A... Apr 6, 2011 - 8:24 PM
chacha i don't think my coilovers are bad (got them l... Apr 7, 2011 - 11:28 AM
BonzaiCelica it tilts to the left from continuous daily driving... Apr 7, 2011 - 9:04 PM
delusionz NO
Mine also tilts to that side too and mines RHD... Apr 7, 2011 - 11:18 PM
jlive Driveway looks flat, car looks flat, garage door l... Apr 19, 2011 - 12:47 PM
marinos mine is tilting at the right side and it is RHD.
... Apr 25, 2011 - 11:57 AM
czwalga According the lines on the door its flat. The lin... Apr 25, 2011 - 2:17 PM
mkernz22 QUOTE (czwalga @ Apr 25, 2011 - 3:17... May 5, 2011 - 8:30 AM
delusionz Maybe has to do with lots of negative camber in th... Apr 25, 2011 - 5:01 PM
marinos QUOTE (delusionz @ Apr 25, 2011 - 5... May 5, 2011 - 8:07 AM
chacha wow...many thanks....so if you feel like you got a... May 6, 2011 - 12:34 AM
Culpable04 corner balance would fix that May 6, 2011 - 12:51 PM
delusionz On alignment I got 3 deg negative camber left rear... May 11, 2011 - 12:12 AM
Culpable04 there is no camber adjustament from factory on our... May 14, 2011 - 3:25 PM
TerBeau indeed there is a little camber adj brah. top bolt... May 15, 2011 - 9:11 PM
Culpable04 I meant for the rear, there is no camber adjustmen... May 16, 2011 - 10:13 AM
TerBeau gotchya i was gunna say the rear deff dont. May 16, 2011 - 3:05 PM
delusionz I remember the rear-most bottom swingarms of my ol... May 17, 2011 - 8:01 PM
TerBeau dont think we have that May 17, 2011 - 9:32 PM
Culpable04 we have that, but that's for toe in / tow out ... May 21, 2011 - 11:23 AM![]() ![]() |
| Lo-Fi Version | Time is now: July 10th, 2026 - 9:34 AM |
