> no start after swap
post Apr 5, 2011 - 12:29 PM
wvuguy
Joined Mar 1, '11
From Morgantown, WV
I swaped 7AFE in my 94 celica ST. Now the only way to start is to spray some throttle body cleaner in intake and it starts right up. I changed the fuel filter, verified there is spark when cranking and fuel injectors fire. Changed out the temperature sensor. Double checked all wiring and vacuume lines.
One thing is noticed is once the engine is running, the rpm will flicker if I turn the headlights on. Also If I put the car in drive, it shuts down. It will run in reverse though.
Any idea? thanks.
- wvuguy   no start after swap   Apr 5, 2011 - 12:29 PM
- - stwin2   check ur fuel pump and the injector gaskets   Apr 5, 2011 - 3:23 PM
- - rave2n   What all did you swap? Block,Head, accessories, s...   Apr 5, 2011 - 3:56 PM
- - wvuguy   Fuel pump was running fine 15 days back with the o...   Apr 5, 2011 - 3:57 PM
- - wvuguy   The new engine came with the intake manifold (incl...   Apr 5, 2011 - 4:02 PM
- - rave2n   Should be fine with EGR delete, atleast mine was w...   Apr 5, 2011 - 4:04 PM
- - wvuguy   The new engine came only came with intake manifold...   Apr 5, 2011 - 4:09 PM
- - rave2n   Ugh, might need a expert to help ya then~! Di...   Apr 5, 2011 - 4:09 PM
|- - wvuguy   QUOTE (rave2n @ Apr 5, 2011 - 5:09 P...   Apr 5, 2011 - 5:25 PM
- - wvuguy   Not yet but thats a good idea. I am going to try t...   Apr 5, 2011 - 4:13 PM
|- - rave2n   QUOTE (wvuguy @ Apr 5, 2011 - 4:13 P...   Apr 5, 2011 - 4:15 PM
- - wvuguy   I ended up replacing the fuel pressure regular onl...   Apr 5, 2011 - 9:11 PM
|- - rave2n   QUOTE (wvuguy @ Apr 5, 2011 - 10:11 ...   Apr 6, 2011 - 7:51 AM
- - wvuguy   I have checked the timing over and over again. As ...   Apr 6, 2011 - 8:03 AM
- - rave2n   I never completely bypassed the EGR in sense of no...   Apr 6, 2011 - 10:13 AM
- - wvuguy   Thanks rave2n. I am gonna do that once I swap the ...   Apr 6, 2011 - 1:23 PM
|- - rave2n   QUOTE (wvuguy @ Apr 6, 2011 - 2:23 P...   Apr 6, 2011 - 4:23 PM
- - wvuguy   I have disconnected the battery a few times so I w...   Apr 6, 2011 - 7:59 PM
- - rave2n   You really gota change out to your original manifo...   Apr 7, 2011 - 10:37 AM
- - wvuguy   I changed out the throttle body today which has al...   Apr 7, 2011 - 12:22 PM
- - rave2n   Cool, no problem. Double check the injectors seat...   Apr 7, 2011 - 12:28 PM
- - wvuguy   I rented the fuel pressure testing kit from autozo...   Apr 8, 2011 - 9:52 AM
- - wvuguy   Found some time to take the intake out. While at i...   Apr 8, 2011 - 1:30 PM
- - wvuguy   Fixed! Had to take the starter out to tighten ...   Apr 8, 2011 - 8:11 PM
- - rave2n   Combo of both in my opinion. I don't think a ...   Apr 8, 2011 - 10:51 PM
- - wvuguy   lol thats awesome. Learn some thing every day.   Apr 8, 2011 - 10:54 PM
Lo-Fi Version Time is now: June 21st, 2026 - 11:19 AM
