Apr 7, 2011 - 12:19 PM
Enthusiast ![]() ![]() ![]() Joined Jul 5, '09 From Katy/houston Currently Offline Reputation: 16 (100%) |
Some of you guys might know my problem...atleast the major one,
my engine ran out of oil and started making this noise, ![]() ever since that day, i drove my car to my autotech class and its just been sitting there, and waiting on a new engine... NOW, my dads 01 Audi A6TT is leaking oil and makes the same noise[ when its low/nearly empty on oil we add 3-4 quarts and the noise stops... (dont worry about that car its going to the shop soon) my question is, if i do another oil change, and maybe add some 'lucus' (or oil thickener?) will be car be normal again? Or atleast safe to drive? This post has been edited by Malhar95: May 17, 2011 - 12:39 PM -------------------- For Sale:OEM tail lights - make offer
Apr 7, 2011 - 6:30 PM
Enthusiast ![]() ![]() ![]() Joined Nov 25, '08 From dillsburg pennsylvania united states Currently Offline Reputation: 12 (100%) |
hmm this sounds familiar man!! its goota be a rod. deff sounds like a deep knowck. oil change will not fix in my opinion.. sorry
-------------------- ![]() those with golf balls golf those with real balls race |
Apr 7, 2011 - 10:53 PM
the damage is done, the bearing is toast. that engine needs a rebuild
Apr 8, 2011 - 11:31 AM
so there's NO WAY an oil change would save the car?
is it worth trying atleast? i mean im already preparing/saving money for a new-used motor so.. -------------------- For Sale:OEM tail lights - make offer
Apr 8, 2011 - 1:56 PM
it doesnt work that way. ill try to explain.
your oil pump provides pressure in the engine. oil passes through journal through the crankshaft to the rod bearings. a very thin layer of oil provides the lubrication between the crank surface and the bearing. when you have no oil then the oil barrier is gone and you have metal on metal contact and friction. thats VERY BAD! very soon after the bearing will bond with the crank and spin inside the rod journal. once that happens you will have metal shaving flying all throughout the system. the engine is a ticking time bomb. the rod is now bouncing around the crankshaft, thats the knocking sound you hear. the damage is done and its only going to get worse. changine the oil is not going to save you do a search for my thread on rebuilding the 7A-FE. i have over 100 pictures showing these parts to give you an idea whats going on in there -------------------- 2001 Celica GT-S Turbo
Apr 8, 2011 - 3:16 PM
Enthusiast ![]() Joined Mar 1, '11 From Morgantown, WV Currently Offline Reputation: 0 (0%) |
My celica made a similar noise. I dropped the oil pan and found spun bearing. For me, replacing the motor myself was the most cost effective way of getting the car back on the road. Paid about $275 for a motor out of a 93 corolla (though I am still trying to get this thing running lol)
Apr 8, 2011 - 11:39 PM
it doesnt work that way. ill try to explain. your oil pump provides pressure in the engine. oil passes through journal through the crankshaft to the rod bearings. a very thin layer of oil provides the lubrication between the crank surface and the bearing. when you have no oil then the oil barrier is gone and you have metal on metal contact and friction. thats VERY BAD! very soon after the bearing will bond with the crank and spin inside the rod journal. once that happens you will have metal shaving flying all throughout the system. the engine is a ticking time bomb. the rod is now bouncing around the crankshaft, thats the knocking sound you hear. the damage is done and its only going to get worse. changine the oil is not going to save you do a search for my thread on rebuilding the 7A-FE. i have over 100 pictures showing these parts to give you an idea whats going on in there what he said. very well put. -------------------- ![]() those with golf balls golf those with real balls race |
Apr 9, 2011 - 1:31 AM
Enthusiast ![]() ![]() ![]() Joined May 6, '08 From Lisarow, NSW, Australia Currently Offline Reputation: 0 (0%) |
It's possible to have some tappet noises especially when it gets low but that is more than simple tappet noise, does your dads audi tap as loud as your celica is?
Apr 20, 2011 - 12:09 PM
It's possible to have some tappet noises especially when it gets low but that is more than simple tappet noise, does your dads audi tap as loud as your celica is? i guess its not that loud but probably becuase of all the sound 'deadner' (sound reducing stuff) betweer the fenders,hood, bumper and firewall etc. same sort of sound though -------------------- For Sale:OEM tail lights - make offer
Apr 20, 2011 - 1:27 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
My question is why the hell are you letting these cars run out of oil?
Sounds like woman logic to me. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Apr 24, 2011 - 3:14 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) |
My question is why the hell are you letting these cars run out of oil? Sounds like woman logic to me. *like* -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Apr 27, 2011 - 2:16 AM
Enthusiast ![]() ![]() Joined Feb 28, '11 Currently Offline Reputation: 5 (100%) |
Some of you guys might know my problem...atleast the major one, lol nooooooo buddddyyyy that engine need a new rod or rod bearing if u drive it u will blow up your engine lol trusssttttttt mee i knoooo ivee did that to 3 of my engines haha i tried driving all of them wen i look in my review all i see is car parts laying on the road behind me haha............. dont buy another engine just fix that one all u need is a new rod and piston
my engine ran out of oil and started making this noise, ![]() ever since that day, i drove my car to my autotech class and its just been sitting there, and waiting on a new engine... NOW, my dads 01 Audi A6TT is leaking oil and makes the same noise[ when its low/nearly empty on oil we add 3-4 quarts and the noise stops... (dont worry about that car its going to the shop soon) my question is, if i do another oil change, and maybe add some 'lucus' (or oil thickener?) will be car be normal again? Or atleast safe to drive? This post has been edited by brenton1919: Apr 27, 2011 - 2:19 AM |
May 3, 2011 - 1:52 PM
Enthusiast ![]() Joined Dec 3, '08 From Summerville, SC Currently Offline Reputation: 0 (0%) |
Some of you guys might know my problem...atleast the major one, lol nooooooo buddddyyyy that engine need a new rod or rod bearing if u drive it u will blow up your engine lol trusssttttttt mee i knoooo ivee did that to 3 of my engines haha i tried driving all of them wen i look in my review all i see is car parts laying on the road behind me haha............. dont buy another engine just fix that one all u need is a new rod and pistonmy engine ran out of oil and started making this noise, ![]() ever since that day, i drove my car to my autotech class and its just been sitting there, and waiting on a new engine... NOW, my dads 01 Audi A6TT is leaking oil and makes the same noise[ when its low/nearly empty on oil we add 3-4 quarts and the noise stops... (dont worry about that car its going to the shop soon) my question is, if i do another oil change, and maybe add some 'lucus' (or oil thickener?) will be car be normal again? Or atleast safe to drive? No no, if a bearing was spun, there are more than likely scouring marks on the crank shaft. Crank will either need replaced, or machined. Quite honestly, as cheap as a used engine is, just put a new motor in. You're going to have more money wrapped up in machining costs than what a used engine would cost you. This post has been edited by PhoenixTech: May 3, 2011 - 1:53 PM -------------------- www.tweakdperformance.com
sales@tweakdperformance.com |
now with alot of thinking and help, ive decided to change the engine, and then 'rebuild' this engine when i get time...since i wont be in a hurry, i can take my time and money and not cheap out on parts like i did last time...hopefully make a beast out of the old one
so this brings out another question: im looking around local junk yards, every time i ask for a celica 2.2, they say around 500-700 is that normal?? i thought our motors were REALLY cheap, and besides the price, what do i look for when buying the engine, i heard alot of times that "compresion test only tells part of the story" so besides a compression test, what else should i be looking at? always appriciate your help guys! -------------------- For Sale:OEM tail lights - make offer
May 17, 2011 - 12:48 PM
Remove the valve cover and check for sludge.
May 17, 2011 - 12:55 PM
Remove the valve cover and check for sludge. thank you... and does anybody know the specs for the compression ratios? what should the results read? -------------------- For Sale:OEM tail lights - make offer
May 17, 2011 - 2:13 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 15, '10 From The Best Coast Currently Offline Reputation: 12 (100%) |
Compression tests are more about uniformity between all the cylinders. Different compression testers will rear differently. As far as the engine i would:
-Check the plugs when you pull them -Check the oil cap like matt said -If your taking the tranny drain the fluid and look for metal pieces. Are you going to pull the engine yourself?Or will the yard do it? |
May 17, 2011 - 5:04 PM
![]() Enthusiast ![]() ![]() ![]() Joined Nov 18, '10 From montreal Currently Offline Reputation: 0 (0%) |
now with alot of thinking and help, ive decided to change the engine, and then 'rebuild' this engine when i get time...since i wont be in a hurry, i can take my time and money and not cheap out on parts like i did last time...hopefully make a beast out of the old one so this brings out another question: im looking around local junk yards, every time i ask for a celica 2.2, they say around 500-700 is that normal?? i thought our motors were REALLY cheap, and besides the price, what do i look for when buying the engine, i heard alot of times that "compresion test only tells part of the story" so besides a compression test, what else should i be looking at? always appriciate your help guys! lol no ! you can find 5sfe a lower price, i have on e myself, and i want to sell it fast for 150 $... |
May 17, 2011 - 5:08 PM
Enthusiast ![]() ![]() Joined Mar 26, '10 From Portsmouth, OH Currently Offline Reputation: 2 (100%) |
now with alot of thinking and help, ive decided to change the engine, and then 'rebuild' this engine when i get time...since i wont be in a hurry, i can take my time and money and not cheap out on parts like i did last time...hopefully make a beast out of the old one so this brings out another question: im looking around local junk yards, every time i ask for a celica 2.2, they say around 500-700 is that normal?? i thought our motors were REALLY cheap, and besides the price, what do i look for when buying the engine, i heard alot of times that "compresion test only tells part of the story" so besides a compression test, what else should i be looking at? always appriciate your help guys! motors should be a lot cheaper than that.. ask for the camry motor (whatever year is appropriate for your car) and see where that gets you on price |
May 17, 2011 - 6:44 PM
QUOTE -Check the plugs when you pull them -Check the oil cap like matt said -If your taking the tranny drain the fluid and look for metal pieces. Are you going to pull the engine yourself?Or will the yard do it? no the yard pulls it out.... i dont need a tranny soo.. and by oil cap i think u mean the complete valve cover rite? i mean its only being held by the 4 bolts on top rite? QUOTE lol no ! you can find 5sfe a lower price, i have on e myself, and i want to sell it fast for 150 $... if your anywhere 200mi. close to houston ill get it today! if not can you check shipping to 77450? if im saving even few bucks, ill rather get it from a 6gc member than a local junk yard, i dont really trust them QUOTE motors should be a lot cheaper than that.. ask for the camry motor (whatever year is appropriate for your car) and see where that gets you on price ask that too, same price! sometimes, didnt even mention what car, just said toyota 2.2L and still around the same figure, one guy told me "750 without warranty!" lol, even im not that dumb -------------------- For Sale:OEM tail lights - make offer
| Lo-Fi Version | Time is now: August 26th, 2026 - 4:47 AM |
