> 3sgte, JDM swap
post Apr 15, 2011 - 11:35 PM
Bladey
Joined Apr 15, '11
From Auckland, NZ
Hello all, i have been reading your forum quite a while now and love it, and what a car the celica is smile.gif
i have a 1996 st202 3sge 5 speed manual currently and would been keen to do a 3sgte swap, i have a few questions of corse and ive researched a lot but most of the swaps are american and hence are quite different ( engine, LHD, clutch, wiring) etc
So i have access to a 3sgte from a st185 or sw20 mr2 for quite cheap (being in NZ has its advantages)
if i get one of these engines how hard is it to put in? will i need to do the hybrid clutch set up as i have read about? will the ecu and wiring be quite difficult and how hard is it to make it a front mount intercooler? as getting a gt4 hood is almost impossible and if so 700 bucks is far to much imo
Any other things i may have to worry about?
cheers guys
post Apr 16, 2011 - 1:48 AM
Rusty
Joined Nov 5, '07
From New Zealand
Heres your GT4 hood, $500 NZ (look you already saved $200.) But should look at getting the rest of the front (hood latch, bumber and support parts or do a SS-Four front)
The Gen 2 3S-GTE your speaking about has just over 30kw over your 3S-GE (133kw), where as the Gen 3 3S-GTE has over 50kw, and Gen 4 3S-GTE about 60kw, these (gen 3 & 4 3S-GTE) would best suited to swap over imo (*kw taken from flywheel)
The Gen 3 3S-GTE would be the easier of the 3 to swap over, as your carrying it over from a ST205 to a ST202. Less stressful on wiring, no worries about RHD to LHD, the clutch you may still need to do as the USA uses the same* 5 speed trans (S54-##X)
How hard is it to do a swap? Well thats up to you and your know how, $$$, skill level and if you have the tools, space etc or have connects at a garage to get it done there.
And the other thing you have to remember is that this will need to have a lvvta cert (~$500) for the engine swap to be able to keep it legal on the road... plus it may require you to upgrade other parts like your brakes to met the safety standards. And thats $500 each time for a cert, so if you want to install adj. coilovers, wheel spacers, fixed bucket seats etc. Then its smart to get them all installed all at once, then go get a cert, so you only have to pay one fee for getting a cert.
Better yet have some NA fun with your ST202 with suspension mods and for the 3S-GE: camshafts, H/C, ECU, high revs......... biggrin.gif thumbsup.gif
...or you could buy a real ST205 GT-Four?
post Apr 16, 2011 - 4:08 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
that hybrid clutch thing is only for the USA guys, their 5s-fe/s54 has different **** to us
Mike W
269awhp / 273ft-lbs
post Apr 16, 2011 - 4:11 AM
delusionz
Joined Feb 11, '08
if u can get a newer 3sgte its got advantages of more power out of the box
3sgte gen 3 will be easier to wire in
but gen 2 is said to be the stronger block
Mike W
269awhp / 273ft-lbs
post Apr 16, 2011 - 8:26 PM
Bladey
Joined Apr 15, '11
From Auckland, NZ
Cheers guys, Yeah celica's are pretty common over here but heaps of 3sfe frown.gif
Ye i would perfer to get a gen 3 but they are quite hard to find and redline want 3k for theres which i feel is a bit of a rip, also reading the MR2 power primer the gen 2 can make quite a bit of power at stock just buy increasing the boost to 15psi ( before fuel cut off)
what kinda brakes will i need for a cert? my car already has adjustable coil overs so that should be ok
Cheers Guys
post Apr 17, 2011 - 5:56 AM
delusionz
Joined Feb 11, '08
Do you have front twin pots already? If not try find a set of those
Mike W
269awhp / 273ft-lbs
post Apr 17, 2011 - 5:59 AM
delusionz
Joined Feb 11, '08
If you cant get a gen3 then get a gen4. Or don't bother, Just sell up and get an ST205 lol... you get alot more car for the money compared to swapping a motor
Mike W
269awhp / 273ft-lbs
post Apr 17, 2011 - 8:37 AM
Bladey
Joined Apr 15, '11
From Auckland, NZ
I have factory 2 pots, its ss II with a LSD, so gen 3 or gen 4? is gen 2 really that difficult?
post Apr 17, 2011 - 4:28 PM
PolliS_5S-FE
Joined Aug 29, '08
theres a decent looking gt4 on trademe at the mo for $7500 asking price. 250km though the guy seems pretty desperate to sell it tongue.gif
Edit, theres also a 3sgte out of caldina thats done 128km for $1400 on tm, complete apparently
This post has been edited by PolliS_5S-FE: Apr 17, 2011 - 7:53 PM
post Apr 17, 2011 - 6:23 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (Bladey @ Apr 16, 2011 - 9:26 PM) *
With just those minor upgrades on the gen 2, it will equal just about the same as a stock gen 3 engine. If you do the same mods to both engines, the gen 3 will have a bit more power than the gen 2
post Apr 18, 2011 - 2:43 AM
Bladey
Joined Apr 15, '11
From Auckland, NZ
Ye found the caldina, there was a St185 3sgte on ther a while ago for 500 that i was about to buy, on a side note anyone know where to get a rear strut from? thanks for the mkernz, do gen 2's use MAF or MAP sensors?
post Apr 18, 2011 - 3:53 AM
Rusty
Joined Nov 5, '07
From New Zealand
the brakes are up to your certifers opinion so best to get in touch with a certifer who can cert engine conversions. Since you already have adjustable coilovers, you've already undergone a cert... haven't you wink.gif
Gen 2 uses AFM/MAF (same thing)
and I've pm'ed you regarding the rear strutbrace.
post Apr 18, 2011 - 4:13 AM
delusionz
Joined Feb 11, '08
QUOTE (mkernz22 @ Apr 18, 2011 - 11:23 AM) *
It makes no sense to go Gen 2 in NZ. You don't understand we have all the JDM cars here, a ct20b is hard to come by on it's own though since they've all been snapped up by Gen2 MR2 and ST185 owners.
It makes sense in the USA as you have local stock of Gen 2 and would have to import Gen 3 making Gen 2 + mods an equally feasibile option.
Here the Gen 2 had it's day, and died out a long time ago when every man and his dog owned and raped an SW20 or ST185 (The market value of an ST185 from 2005 to 2009 went from $5000 to $2000 for a good runner). Now they are hard to come by.
The Gen 3 went much the same way, except started with fewer numbers.
The Gen 4 is in abundance at the moment as GT-T Caldinas are wrecked left right and centre.
Anyways, going off topic here so the bottom line is. Gen 2 requires alot more effort to install and makes low power for a 2L turbo. the upgrade doesnt really make good value for the money and time spent
Mike W
269awhp / 273ft-lbs
Lo-Fi Version Time is now: July 12th, 2026 - 4:12 AM
