> too much negative camber
post Apr 17, 2011 - 2:35 PM
yellowchinaman
Joined Aug 11, '08
From London
My rear arms are solid and I can't adjust them. I have too much negative camber. Camber bolts gives too little effect as I need to loose about 2 degs. Any thoughts on how to correct this?
post Apr 17, 2011 - 2:46 PM
4-eyed-freek
Joined Apr 17, '10
From U.P. michigan GO STATE
your rear arms are solid? hmm the only thing i can think of that would be hard and most likely not safe, but drill new holes for the struts on top.
It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
Celica: The name is derived from the Spanish word for "heavenly" or "celestial".
Back-2-Back July COTM 15&16
post Apr 17, 2011 - 11:16 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Do you use BC coilovers?
I have the same thing, with the drop comes alot of negative camber. hell I have so much negative camber I had to put wheel spacers to stop my tyres rubbing the springs.
Apparently BC has optional ST205 camber tophats for the rear that you can order.
Mike W
269awhp / 273ft-lbs
post Apr 18, 2011 - 3:01 PM
yellowchinaman
Joined Aug 11, '08
From London
QUOTE (delusionz @ Apr 18, 2011 - 12:16 AM) *
I was the first in the UK (maybe in the world) to have fitted the BC coilovers and wrote a review on them. smile.gif
I never had the problem with wheel rub with my rims and also at the time they never came with adjustable top mounts.
However even now with adjustable top mounts in the rear, the only way you can move them out enough to correct the camber is by cutting into hole at the top more for the strut to move out enough because the circular hole is too small.
post Apr 18, 2011 - 3:06 PM
Culpable04
Joined Apr 17, '06
From New Jersey
raise the car back up just enough to get an adjustment with the camber bolts ( +/- 1 degree ? )
post Apr 18, 2011 - 4:57 PM
delusionz
Joined Feb 11, '08
I'm running 225/50ZR16 tyres, If I was running 215's like stock spec they wouldn't scrub
Mike W
269awhp / 273ft-lbs
post Apr 19, 2011 - 2:11 AM
yellowchinaman
Joined Aug 11, '08
From London
QUOTE (Culpable04 @ Apr 18, 2011 - 4:06 PM) *
sorry but camber bolts are rubbish and I barely get 1 deg on them also I don't want to raise my ride height any more.
QUOTE (delusionz @ Apr 18, 2011 - 5:57 PM) *
I am running 225/40/18's with Millenium Revolution.
I think to resolve this I'm going to need new camber control arms but stock ones don't go in enough so maybe have to make my own.
post Apr 19, 2011 - 3:03 AM
delusionz
Joined Feb 11, '08
yeah shorter swingarms.
So you do have the camber tophats in the rear and it didn't help?
with shorter swingarms that will narrow the track so you'll need to run spacers.
the reason your 225's dont scrub and mine do is because i have factory wheels with ET45 offset. you probably have ET40 or less on those 18's which is enough to clear it.
I only needed 5mm slipon spacers to do the job, but those are illegal in my country so i got bolt on hub centric 15mm spacers effectively giving me factory 16x7.5 ET30
This post has been edited by delusionz: Apr 19, 2011 - 3:05 AM
Mike W
269awhp / 273ft-lbs
post Apr 19, 2011 - 7:33 AM
yellowchinaman
Joined Aug 11, '08
From London
QUOTE (delusionz @ Apr 19, 2011 - 4:03 AM) *
ET13
post Apr 19, 2011 - 8:05 AM
delusionz
Joined Feb 11, '08
you have ET13 wheels? lol they must stick out out the guards alot
you rolled the bottom lip?
Mike W
269awhp / 273ft-lbs
post Apr 19, 2011 - 8:24 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
If you're only getting 1 degree from camber bolts then you're doing it wrong.
**** Photobucket
post Apr 19, 2011 - 10:04 AM
azian_advanced
Joined Apr 18, '05
From Calgary
I just had an idea. can't you replace the rear solid lateral arm with another front lateral adjustable arm? that way you all the lateral arms are adjustable? and just shorten the arms to give more positive camber change.
post Apr 19, 2011 - 1:20 PM
You could always modify the stock arms to make them adjustable. They are hollow units, measure up from the outter mount about 2 or 3" and slice out about an inch. Tap the inside of the arm and thread in a stud. Tap the other side and adjust. I don't believe it would weaken the unit.
This post has been edited by playr158: Apr 19, 2011 - 1:21 PM
post Apr 19, 2011 - 4:25 PM
yellowchinaman
Joined Aug 11, '08
From London
QUOTE (delusionz @ Apr 19, 2011 - 9:05 AM) *
Nope. Fits perfectly flushed in the front and I'm going to put 20mm in the rears to make them match.
QUOTE (95CelicaST @ Apr 19, 2011 - 9:24 AM) *
How so? I didn't think it's physically imposable to adjust them in any other way.
QUOTE (azian_advanced @ Apr 19, 2011 - 11:04 AM) *
QUOTE (playr158 @ Apr 19, 2011 - 2:20 PM) *
Yes which is why I think the only way forward is to make my own.
Maybe I'll source a set of stock ones and send it off or maybe buy a set of BMW control arms and modify them.
The question is how much shorter should I go?
post Apr 19, 2011 - 6:05 PM
delusionz
Joined Feb 11, '08
Where do the camber bolts go anyways? Do they replace the swingarm bolt? Because I don't see any way of adjusting camber back there except for the top suspension mounting position and the swingarm length. its the only way to tilt the rear wheels back and forth.
it's different to an st202/st204 back there which has a thin piece of crap arm with a long adjusting nut built into it. such a weak design would fail on a GT4 as you gotta remember these wheels have to deal with more weight and a transfer of 50% engine torque
and this arm holds up the whole rotating assembly including the wheel and the hub
Mike W
269awhp / 273ft-lbs
post Apr 20, 2011 - 12:34 PM
95CelicaST
Joined Feb 5, '05
Here.
**** Photobucket
post Apr 20, 2011 - 2:16 PM
QUOTE (yellowchinaman @ Apr 19, 2011 - 5:25 PM) *
I wouldn't section out more than an inch.
You can always cut more off...adding back isn'tas easy.
post Apr 25, 2011 - 5:33 AM
yellowchinaman
Joined Aug 11, '08
From London
I had a brain storm
If a camber bolt gives +/- 1.75 degs.
What if I put a bolt at the bottom hole as well as the top?
Will that give me about 3 degs?
post Jul 29, 2011 - 8:06 PM
delusionz
Joined Feb 11, '08
im thinking, weld up the mounting holes and redrill them, then use st205 optional rear camber tophats to get them even on both sides
Actually , stuff the tophats, custom adjustable swingarms FTW
This post has been edited by delusionz: Jul 29, 2011 - 8:08 PM
Mike W
269awhp / 273ft-lbs
Lo-Fi Version Time is now: September 2nd, 2026 - 6:38 PM
