> Wireing in a SAFC II
post Apr 20, 2011 - 7:24 PM
jeffrosie
Joined Sep 11, '08
From Surrey Unitedkingdom
Just want to get a little help in wireing a SAFC II up to my 3SFE which has recieved a CT26. Will only be running actuator boost - 7psi, so nothing big. Running through a ST185 intercooler mounted in front with suitable mods. Will be retarding timing by about 5 degrees.
Red - Power
Brown - Ground, ECU side
Black - Ground about 1 cm after brown
Green - RPM
Grey - Throttle Signal
Purple - knock
White - Airflow pressure Signal Input
Yellow - Airflow pressure Signal Output
Blue - not used
Pink - not used
Orange - not used
Am I right with this?
Please correct if not........
- jeffrosie   Wireing in a SAFC II   Apr 20, 2011 - 7:24 PM
Lo-Fi Version Time is now: August 30th, 2026 - 11:53 PM
