> cracks in bodykit, how to fix..
post Apr 22, 2011 - 3:08 AM
Jamaz12
Joined Feb 11, '11
From Australia
Hi all,
just noticed some small chips and cracks in the body kit and was wondering what is the easiest / most cost efficient way of fixing this..
all ideas are appreciated..
Replies (1 - 3)
post Apr 23, 2011 - 7:39 PM
sincerelyseb
Joined Jul 8, '09
From DuBois PA
some fiberglass, sand paper and paint
post Apr 24, 2011 - 8:34 AM
burningice1989
Joined Dec 5, '09
From Harlingen, tx
Depends on the crack I think. I used bondo on some bad parts on my car.
post Apr 27, 2011 - 8:05 AM
NYp8tBaller07
Joined Jan 30, '11
From Albany, NY
if its a little ding use some fiberglass resin+hardener on the outside and for cracks you want to remove the bumper ect. place some fiberglass resin on the inside and cover the surrounding area of the crack. From there place a sheet of fiberglass over the crack and cover with FG resin+hardener. Then place a sheet of garbage like plastic over and re enforce it with something (usually clamps and wood). once all is dry sand down the excess resin so the body is smooth. You can then quickly spray some primer; once dry, paint! =)
I had to do this on my last celica with a kit after some girl cracked my rear bumper while I was sitting at a red light.
Power in Balance
90 ST coupe- Sold
95 ST hatch- Dead :’(
02 Impreza RS- DD
Lo-Fi Version Time is now: August 31st, 2026 - 9:35 AM
