Apr 25, 2011 - 3:53 PM
Enthusiast Joined Apr 25, '11 From charlotte Currently Offline Reputation: 0 (0%) |
ok i just put a new strut and mounting plate in my celica. i still got the same bouncing noise comin from it. think i got a bad strut? anything else i need to check for?
Apr 25, 2011 - 11:11 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) |
check your bushings..
May 1, 2011 - 10:25 AM
well i replaced the mounting plate with it i thought that was the only bushing....
May 3, 2011 - 4:14 AM
Enthusiast Joined Sep 20, '10 From Kansas City, MO Currently Offline Reputation: 0 (0%) |
If you follow your rear suspension down, you'll find there are two stabilizer arms per side, the strut side could have a worn or loose thru-bolt, if not, follow it up to underneath the middle of the car, where the arms almost converge, there are bushings in each side that like to eventually squeak a lot, and I guess if the bushings were gone, you'd have a metal-on-metal knock. Just push up and down on the trunk (or hatch) when its parked and listen closely. Go from there.
May 4, 2011 - 5:15 PM
stem bushings can be gone, springs are hella worn, etc.
| Lo-Fi Version | Time is now: September 18th, 2026 - 7:07 AM |
