> Will the Auto Transmission from a Camry fit my Celica?, 5SFE equipped Celica
post Apr 26, 2011 - 5:33 AM
THE20V
Joined Jul 13, '09
From Australia
The gearbox in the Camry and the Celica are both called A140E. But the guy at the wreckers is saying they're not the same. Who can confirm this?
This post has been edited by THE20V: Apr 26, 2011 - 6:50 PM
2 X ST165 GT4's
1 X ST162 Celica
1 X AE82 Corolla Seca SX
1 x AE92 Corolla 20 Valve Turbo (THE20V)
And currently a 1995 Celica SX
post Apr 26, 2011 - 9:30 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
i dont know for sure but ill guess the camry one is very close if not the same. as for the shifting, the vacuume plate in the tranny might be going out. im not an automatic tranny guy. wont touch them
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Apr 26, 2011 - 7:44 PM
THE20V
Joined Jul 13, '09
From Australia
can anyone please assist with the above question?
2 X ST165 GT4's
1 X ST162 Celica
post Apr 27, 2011 - 2:10 AM
brenton1919
Joined Feb 28, '11
QUOTE (THE20V @ Apr 26, 2011 - 7:44 PM) *
YES!if u have a 5sfe engine it will fit it is the same transmission same engine that in the celica just in a different car dont listen to none of them a** holes none of them know what they are talking about they just pull parts
This post has been edited by brenton1919: Apr 27, 2011 - 2:12 AM
post Apr 27, 2011 - 2:41 AM
THE20V
Joined Jul 13, '09
From Australia
are you serious? Ok now I have th SH**TS. Cause I found Camry boxes for $200 and had to shop around for ages to find a Celica Box for $330. Most of them wanted $400 and up.
I considered doing a manual conversion, but was too costly. Was gonna cost around $1,400 installed. Whereas the auto will cost me around $700 installed.
2 X ST165 GT4's
1 X ST162 Celica
post May 5, 2011 - 3:07 AM
brenton1919
Joined Feb 28, '11
QUOTE (THE20V @ Apr 27, 2011 - 2:41 AM) *
yeah bro the celica and the cam both have the same engine same transmission its just a different car it might be set up to shift different but that all in the computer the only reason they say it wont fit because they see it as its not the same car so it fit that b.s they say that at every junk yard u go to
post May 5, 2011 - 7:48 AM
mkernz22
Joined May 10, '10
From MA
QUOTE (THE20V @ Apr 27, 2011 - 3:41 AM) *
Are you doing the swap yourself or are you having a shop do it? Only costed me about $700 cause I did it myself, and I had a full parts car though..
It's pretty easy if you are just going to swap out auto transmissions, you could easily do it yourself if you have all the right tools
post May 16, 2011 - 3:29 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Since we're all guessing here,
My guess is they are practically the same, but there will be something on the Camry gearbox that throws a spanner in the works, possibly a different mount, or the speedo drive, or something to do with the ECT-S or even the axels.
But then again the wreckers also tried to tell me a 3S-GE alternator wouldn't fit a 3S-GTE, I ended up saving $250 on a suitable part
Mike W
269awhp / 273ft-lbs
post May 20, 2011 - 8:51 PM
csscza
Joined Apr 28, '10
From Ft Worth
take a look at the mounts and Im pretty sure they are different but those can be swapped I went and looked at a couple and the mounts were different same trans but different mounts
Lo-Fi Version Time is now: August 25th, 2026 - 3:40 PM
