> My toy is here, its huge!!!, bought a compressor
post Apr 27, 2011 - 8:56 AM
I just came to realize that my compressor cant keep up with me, as it starves a lot.
single stage double stage, single, twin piston?
what are u guys running.
I barely get 4cfm at 90 psi, i need at least 7 or 9 at 90 psi to run a blaster properly, and porper paint guns at 40 psi that require 10 cfm.
so, i know nothing that has wheels will help me, and its going to be 220 volts,
but just in case if you have something let me know what u are using.
I have a 2hp single piston motor, 110volts with 26 gallon tank.
This post has been edited by njccmd2002: Jun 22, 2011 - 6:29 PM
post Apr 27, 2011 - 11:51 AM
KAOS
Joined Apr 18, '06
From Calgary, Canada
Good thread - I'm interested too, as I've finally talked my wifey into letting me upgrade the compressor.
Mine, however, doesn't need to be portable. In fact, the less portable; the better. smile.gif
post Apr 27, 2011 - 8:17 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
You need ones like these...
post Apr 28, 2011 - 12:34 AM
I've been eyeing one at harbor freight lately...but first I need to upgrade the wiring in the garage...
post Apr 29, 2011 - 2:29 PM
QUOTE (Bitter @ Apr 27, 2011 - 8:17 PM) *
specs?
post Apr 29, 2011 - 7:14 PM
Bitter
Joined Mar 11, '06
Uh...big.
I think the green one is like 100-120 gallons, 2 stage (or maybe just two cylinder?), around 5hp motor I think. I never looked at it too hard...I just use it. I know its 220 volt and has its OWN 30 amp breaker.
post May 16, 2011 - 7:33 PM
the compressor is sold by tractor supply
http://www.tractorsupply.com/tools/air-com...pressor-3310006
60 gallon, 3hp engine, 220 volts.
Flow Rate : 11.5 SCFM @ 40 PSI, 10.2 SCFM @ 90
the compressor itself is 400, plus accessories, comes to 600 (filter, hose, regulator, breaker etc)
any comments, i have not bought it but is the most affordable to date.
post May 30, 2011 - 7:28 PM
Celiracer18
Joined Aug 23, '05
From Princeton, Minnesota
we had one just like that ^^^ on the farm and IIRC the pump went out pretty quickly or the motor was crap. not sure but its been quite a while. other than that it was great!
-Brian
post Jun 19, 2011 - 10:49 PM
bought a compressor today, picking it up tomorrow.. 80 gallons baby, not cheap.....
post Jun 22, 2011 - 6:31 PM
here it tis guys, ill review it as i use it,
This post has been edited by njccmd2002: Jun 22, 2011 - 9:44 PM
post Jun 22, 2011 - 6:42 PM
mak5603
Joined Oct 20, '08
Pretty boss compressor you got there.
2014 Toyota Rav4 XLE
post Jun 22, 2011 - 7:06 PM
Bitter
Joined Mar 11, '06
Cool, that crate actually makes a good stand so it won't vibrate the floor/house as badly. It also gets it up off the floor so accessing the drain valve is easier.
post Jun 22, 2011 - 7:20 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
Hmm you pay $30 and your pictures still come out sideways..
post Jun 22, 2011 - 8:47 PM
NYp8tBaller07
Joined Jan 30, '11
From Albany, NY
I would just use a 88ci/4500psi paintball tank lol XD
Power in Balance
90 ST coupe- Sold
95 ST hatch- Dead :’(
02 Impreza RS- DD
post Jun 22, 2011 - 9:45 PM
i need air, lots of air, ill be running air hungry tools from here on...
ime getting very serious with my 1gc's..
post Jun 26, 2011 - 6:54 AM
Stambo
Joined Apr 23, '08
From Muskego,Wi
using a da takes a lot of air. I think my garage compressor kept setting the circuit breaker for it loose every 5 mins.
2nd Gen 3s-gte.... It lives!
97celiman
post Jun 26, 2011 - 8:44 AM
QUOTE (njccmd2002 @ Jun 22, 2011 - 7:31 PM) *
ohhhh niiicccee!
post Jun 28, 2011 - 8:10 PM
I cant wait to go back home and play with it....
post Jun 28, 2011 - 9:40 PM
QUOTE (njccmd2002 @ Jun 28, 2011 - 9:10 PM) *
that's what she said.
I picked up a 60 gallon link
post Jun 29, 2011 - 10:51 PM
Uuuhhhh. I like the drying unit, or is it a filter. Im in fla right now. But be home tomorrow to play....
Lo-Fi Version Time is now: June 11th, 2026 - 3:56 PM
