> need to know
post May 7, 2011 - 7:08 AM
gtprominient
Joined Feb 3, '11
From jamaica
hi does anyone if metal exhaust manifold gasket is available for the gen3 3sge
post May 7, 2011 - 12:12 PM
Needles
Joined Nov 18, '10
From montreal
i dont know if ist metal lol laugh.gif its look like it is....
oups sorry, i didnt notice for 3SGE, that one is for 3sgte,, kindasad.gif ,,,sorry kindasad.gif
This post has been edited by Needles: May 7, 2011 - 12:16 PM
post May 7, 2011 - 6:16 PM
korban
Joined Feb 5, '09
From New Zealand
I know that the factory 3SGTE exhaust manifold gasket is a 3 layer metal gasket. It should have the same stud pattern as the 3SGE.
part: 17173-88581
That one needles is holding is the turbo exhaust gasket, and looks like a standard pressed/stamped one out of generic gasket paper.
post May 7, 2011 - 10:23 PM
gtprominient
Joined Feb 3, '11
From jamaica
QUOTE (korban @ May 7, 2011 - 7:16 PM) *
part: 17173-88581
part: 17173-88581 that one cannot work the gen 3 3sge has bigger ports and the lug pattern is different.
post May 8, 2011 - 6:07 PM
jeffrosie
Joined Sep 11, '08
From Surrey Unitedkingdom
2nd gen 3SGE has same stud pattern as 2nd gen 3SGTE
3rd gen 3SGE has same stud pattern as 3rd gen 3SGTE
so if yours is 3rd gen, then...........
post May 8, 2011 - 6:43 PM
Needles
Joined Nov 18, '10
From montreal
left st185-------3sgte 2nd gen
right st205------3sgte 3nd gen
post May 8, 2011 - 9:45 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
The gasket part numbers are different 3s-ge to 3s-gte, and probably different port spacing.
Needles: the turbine flange on the right is a CT26/ST185 flange, the downpipe on the left doesn't look like it fits any Celica or MR2 at all.
Mike W
269awhp / 273ft-lbs
post May 8, 2011 - 9:57 PM
delusionz
Joined Feb 11, '08
This is the back of a CT26/ST185 turbo
an ST205/CT20B flange goes on the same except some needs to be grinded where I put the red mark to the left on the flange so the wastegate doesnt get stuck, and theres a 7th hole for an extra stud which the 205/20b uses that the 185/26 does not.
This post has been edited by delusionz: May 8, 2011 - 9:57 PM
Mike W
269awhp / 273ft-lbs
post May 9, 2011 - 12:09 AM
korban
Joined Feb 5, '09
From New Zealand
QUOTE (gtprominient @ May 7, 2011 - 10:23 PM) *
part: 17173-88581
That part is for a Gen3 3SGTE (ST205) which is the same lug pattern as the 3SGE?
Like this:
You're after an exhaust manifold gasket right? Goes between manifold and head?
Why is everyone showing turbo flanges?
post May 9, 2011 - 10:11 AM
gtprominient
Joined Feb 3, '11
From jamaica
QUOTE (korban @ May 9, 2011 - 1:09 AM) *
part: 17173-88581
Like this:
Why is everyone showing turbo flanges?[code][/code]
yes the manifold and head but i am tellin you that my port holes are wider and in a differ in position where it meets the head.i bougth a cast iron and it could not fit and bougth one of tubular rev 3mani and it had the same port holes like thecast iron, had to cut the plate off the 3sge mani curve the pipes and weld it back on.
i think i have a spare asbestos gasket lying around i will try taking aic to show what it looks like
post May 9, 2011 - 10:28 AM
gtprominient
Joined Feb 3, '11
From jamaica
QUOTE (delusionz @ May 8, 2011 - 10:45 PM) *
this exactly what i am saying but can the ge be had in metal because mine is in asbestos and it is showing signs of blowing
post May 9, 2011 - 4:39 PM
korban
Joined Feb 5, '09
From New Zealand
Does it look more like one of these?
post May 9, 2011 - 5:14 PM
delusionz
Joined Feb 11, '08
Mike W
269awhp / 273ft-lbs
post May 12, 2011 - 9:17 AM
gtprominient
Joined Feb 3, '11
From jamaica
QUOTE (delusionz @ May 9, 2011 - 5:14 PM) *
look like this
QUOTE (korban @ May 9, 2011 - 4:39 PM) *
looks like the smaller one are those manifold plates
thinking about that, whats the best material to use
post May 15, 2011 - 5:52 PM
korban
Joined Feb 5, '09
From New Zealand
Those flanges I posted were gen2 in case it matched them, and it obviously doesn't. But it still looks the same as the metal gen3 gasket i'm holding, I could take measurements if you want?
post May 17, 2011 - 7:46 PM
gtprominient
Joined Feb 3, '11
From jamaica
QUOTE (korban @ May 15, 2011 - 6:52 PM) *
sorry for the delay in response was off the net for sometime. yes please take measurements
post May 17, 2011 - 10:11 PM
korban
Joined Feb 5, '09
From New Zealand
starting from the left, the distances between the centres of each pipe:
76mm, 96mm, 94mm
starting from left, the width of each port:
56.5mm, 50.6mm, 50.6mm, 50.6mm
post May 28, 2011 - 9:45 AM
gtprominient
Joined Feb 3, '11
From jamaica
sorry for delay in responding i found a material that can make a gasket so i am gonna make one thanks guys 4 ur help
Lo-Fi Version Time is now: August 28th, 2026 - 7:29 PM
