> Plasma Dial Installation
post May 7, 2011 - 2:25 PM
MagnaMorbius
Joined May 7, '11
From Stockport
I recently purchased some indigo dials, and have them all in place in the instrument cluster. The needles move, and everything is good. Except for one thing; which wire do I connect my red power wire to? There are 3 wiring harnesses that fit in to the back of the instrument cluster, one with 10 wires, one with 12 wires, and one with 16 wires. I've got the metal firewall right behind the instrument cluster, so that'll ground, but which wire is the instrument cluster lights? There's so many to pick from and I really think I might cry.
Please help!
Thanks,
Andy.
post May 7, 2011 - 4:59 PM
4-eyed-freek
Joined Apr 17, '10
From U.P. michigan GO STATE
splice into the cigarette lighter. you will have to take the center councle out and what not to get at it but its beter than trying to go into the actual guage harness
It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
Celica: The name is derived from the Spanish word for "heavenly" or "celestial".
Back-2-Back July COTM 15&16
post May 7, 2011 - 11:51 PM
MagnaMorbius
Joined May 7, '11
From Stockport
What are the wiring colours on the cigarette lighter, and which one do I want to splice? And won't that mean the dials are on all the time, rather than just when I turn the sidelights on?
Thanks,
Andy.
post May 8, 2011 - 7:53 AM
ST205WRC
Joined Dec 30, '10
From amarillo texas
if you want them on only when you turn your lights on then splice it into the illumination wire on your radio. if you have an after market deck its normally orange (i know it is on kenwood). you will have to check depending on your deck but that should do the trick.
This post has been edited by ST205WRC: May 8, 2011 - 7:54 AM
post May 8, 2011 - 12:51 PM
MagnaMorbius
Joined May 7, '11
From Stockport
That was absolutely spot on - I wired it to the earth and illumination wires, and it's perfect. Thank you so much for your help.
Andy.
post May 8, 2011 - 1:21 PM
mkernz22
Joined May 10, '10
From MA
You could have wired it to a switch too
post May 9, 2011 - 5:18 AM
ST205WRC
Joined Dec 30, '10
From amarillo texas
QUOTE (MagnaMorbius @ May 8, 2011 - 12:51 PM) *
Andy.
hey no problem, and mkernz yeah you can do that but then you have to worry about a fuse and wire the switch its just a pain then you have to turn it on. ^^ that way you just have to turn your lights on like normal.
Lo-Fi Version Time is now: August 27th, 2026 - 12:59 AM
