May 10, 2011 - 9:18 AM
Enthusiast ![]() Joined Mar 29, '11 From Bloomington, IN Currently Offline Reputation: 0 (0%) |
I'm trying to change the valve cover gasket, but I'm having a hell of a time getting the cover off. The thing's been slooowly leaking oil, and that's all been building up and creating an adhesive layer. On the 7a, there's just the four acorn nuts that hold the cover on right? I feel like I'm missing something because this thing isn't budging. I tried using c-clamps on the left edge and pulling up, but no luck. Any advice?
senick Taking off valve cover May 10, 2011 - 9:18 AM
4-eyed-freek it shouldnt be that hard once you get all the bolt... May 10, 2011 - 9:23 AM
senick What do you mean, the spark plug wires? I don... May 10, 2011 - 10:34 AM
senick Would it be safe to use some liquid wrench around ... May 10, 2011 - 6:48 PM
d3ath2009 when i replaced my timing belt we had to have the ... May 10, 2011 - 7:20 PM
SupraKid remove nuts, take out plug wires, hit the valve co... May 10, 2011 - 7:20 PM
senick Yeah, I'm liking the hammer idea. I'm rel... May 10, 2011 - 8:32 PM
easternpiro1 Before you get the whacking, try to use a rubber h... May 10, 2011 - 11:21 PM
PolliS_5S-FE i think 4eyedfreek meant did u get the gaskets for... May 11, 2011 - 12:32 AM
senick Oh, yeah that makes sense. And yes, I got those. ... May 11, 2011 - 2:49 PM
trdproven yea, just get the bolts off. anything that can pr... May 14, 2011 - 1:41 AM
senick Alright good advice. Yeah, I got gasket seal to s... May 14, 2011 - 3:08 PM
wvuguy When I took mine off it was pretty stuck too. Had ... May 15, 2011 - 10:02 AM
senick OK, I must be missing a bolt somewhere then. I ha... May 15, 2011 - 5:35 PM
wvuguy QUOTE (senick @ May 15, 2011 - 6:35 ... May 16, 2011 - 10:16 AM
mkernz22 You do have to move the wiring harness that goes o... May 16, 2011 - 10:27 AM
senick Ohh...the throttle cable and bracket, didn't t... May 18, 2011 - 9:12 AM
czwalga I took mine off yesterday on the way to removing t... May 18, 2011 - 9:28 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 27th, 2026 - 11:07 AM |
