> TroubleShooting Help, No spark after car shuts off diagnosis needed
post May 10, 2011 - 10:40 AM
luisitol
Joined Apr 14, '06
Hey Guys. I've got a 1996 GT and my car will start, run for anywhere between 30-90 seconds, shut off and then you'll hear anywhere between 4-10 audible "ticks" coming form the distributor (which I'm assuming is the coil still firing). The car then does not turn on after that. No spark is present once it shuts off.
I replaced the cap as it was slightly damaged and then I also replaced the igniter as I know they do go bad on Toyotas. Still having thi sissue though. Anyone able to lend a helping hand on troubleshooting this issue?
My next thought is either a bad distributor, bad circuit opening relay or bad ecu, but I'm sure there are other things to look at. Thanks.
This post has been edited by luisitol: May 10, 2011 - 11:00 AM
Lo-Fi Version Time is now: August 26th, 2026 - 3:49 AM
