> Swapped Celica won't start...HELP!, VERY FRUSTRATING!
post Dec 9, 2003 - 3:26 PM
XSTeknique
Joined Dec 21, '02
Well, everything is plugged in (i assume) and the project of a 2nd gen 3sgte into my 6th gen (st) is almost finished, the engine cranks, but won't turn over. My mechanic has said that there is no current to the igniter coil and no pulsation to the injectors. Any clues? Does this even make sense? My ECU is being tested today or tomorrow, but I don't think that's the problem. It's been 4 months and I'm frustrated...any help is appreciated. Thanks guys.
Replies (1 - 4)
post Dec 9, 2003 - 3:38 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
i had the same problem with mine it was the fuel reducer siloinoid ( i think thats what it is) it has a circle plug with 5 prongs. one is a power and the other four goes to each injector it has to be perfect or it wont run as far as the coil is concerned i dont know what to tell you
edo17982
Joined Dec 21, '02
From Italy
Are you sure you've the right ECU??????????
Also if u made custom wiring check if u made ECU pinouts right....
post Dec 9, 2003 - 4:00 PM
XSTeknique
Joined Dec 21, '02
Well, I bought it as a clip. I don't see why they would remove the ECU from a clip they were selling. And Mike (Qatar) made the wiring. I'm sure he knows what he's doing. I don't even know what the hell at this point...
post Dec 10, 2003 - 4:49 PM
sphinx
Joined Apr 10, '03
From South Central Los Angeles
i have the exact same problem right now.
but i know for a FACT that i am missing the EFI solenoid, but not anymore. i just got it today. So hopefully, it will start.
Lo-Fi Version Time is now: May 16th, 2026 - 8:55 PM
