May 14, 2011 - 5:32 PM
Enthusiast Joined Dec 31, '09 From Ashaway, Rhode Island Currently Offline Reputation: 0 (0%) |
hi guys. i have just about gotten my 3sfte up and running but i still need to wire in my emanage and had a question. I was reading through the forums and read that you dont wire in the ignition wires on the stock harness into the emanage because it will not work properly. is that correct? i thought that you would need to wire it in so that you could retard timing under boost? or does the factory knock sensor compensate the timing while under boost well enough so that it wont be an issue?
| Lo-Fi Version | Time is now: August 23rd, 2026 - 11:54 AM |
