> Help diagnose my gt4 noises **with video**, creaking noise
post May 17, 2011 - 5:18 PM
schmooot
Joined Sep 29, '09
From Prince George, BC CANADA EH!
Well I'm stumped.
Here are the details
94 ST205
Creaking sound...once every wheel revolution
Happens in forward in reverse...more prominent in reverse. Seems to go away when I get up to speed higher than 35ish kmh but maybe I just can't hear it after that. Dead cold it is very quiet but I drove around the block just before the video and it warmed it up enough to be very noisy.
Definitely happening every revolution, clutch in or out, transmission neutral or in gear.
I put it up on jackstands in the shop and ran it but all 4 wheels were quiet...only happens when on the ground (loaded down I suppose). Unless I get it on a rolling road I think that's the best I can hear
Still happens with light to full brake pressure so I doubt it is sticky brake pads.
Wheel weights come very close to the caliper but no touching.
Just put these wheels on last week...with 15mm hubcentric spacers and longer studs. The car was stored all winter in the shop and I ran all last year with the stock rims. and only spacers in the rear...don't really remember hearing noises like this last year with stock rims but there was some wooga wooga noises coming from up front (which also seems to have gotten worse this year)
Seems to be coming from front drivers side but I can hear it well on the pass side as well, and the odd creak on the rear drivers side.
I am highly suspect of the wheel/hub bearings. I just tore apart the pass side and had a look at the hub bearings and it certainly doesn't spin like a bearing should, kind of grindy and hard to turn. but would like some other opinions before I drop the big bucks on a couple new ones. They are closed press-in type and bloody expensive...nothing I can just pull and repack
Anyways...watch the vid and let me hear your thoughts/concerns
Embedded vid
Or if that doesn't work you can just download the vid from me directly
ST205 Crew represent
Challenge Accepted
Replies (1 - 12)
post May 17, 2011 - 7:54 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
I've been chasing rotational noises for years,
Have had to replace all 4 wheel bearings and both superstrut arms to fix the noises,
But what I hear from your video sounds, I've never ever heard from my car.
Yours sounds like its rubbing something like a stray piece of plastic at the top as i noticed the sound happens once for every full rotation.
The sound of my worn wheel bearings (infront) weren't audible until 30kph turning a corner, It was an oscillating metal on metal friction sound. It was obvious in the rear as the wheels developed free play in toe in/out.
Mike W
269awhp / 273ft-lbs
post May 17, 2011 - 7:59 PM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
Can you chuck another set of rims on it to check?
It does happen at the same point in each roation.
Sounds like the tire is rubbing on the guard lining or something, i doubt thats the issue but check anyway.
Pull the wheel off and check of anything is scrubbing on the driveshaft/cv's/crake rotor etc.
I highly doubt its a wheel bearing but check for play anyway.
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post May 17, 2011 - 9:35 PM
TerBeau
Joined Nov 25, '08
From dillsburg pennsylvania united states
wheel bearing!!!!
or axle!
those with golf balls golf
those with real balls race
post May 17, 2011 - 10:21 PM
schmooot
Joined Sep 29, '09
QUOTE (Cuts_the_Pilot @ May 17, 2011 - 5:59 PM) *
No noise with the car up in the air, only on the ground, I was all over underneath there and nothing is rubbing.
I had the one side all apart and the bearings do feel very stiff and dirty when I turn by hand. Then again the sound could very well be coming from the driveshaft itself. I just ordered new bearing kits from the UK, we'll see when they show up
Challenge Accepted
post May 18, 2011 - 3:04 AM
hizzle369
Joined Mar 25, '11
From Vancouver, WA
Yeah I think you need to replace your wheel bearings.
I had a similar sound and I replaced my wheel bearings and it was fine.
post May 18, 2011 - 8:57 AM
schmooot
Joined Sep 29, '09
Thanks, I've got new ones on the way from the UK.
Challenge Accepted
post May 18, 2011 - 3:16 PM
sounds like the clips that hold the brake pads.
Either broken or not greased up.
post May 19, 2011 - 7:17 AM
Euphoria
Joined May 6, '08
From Lisarow, NSW, Australia
Yeah Id say 90% sure its bearings, especially seeing as they make more noise when they heat up! always a good idea to take the disc off and wriggle the flange, if that has play then thats the problem rather than pulling the driveshaft out and having a look behind.
post Oct 8, 2013 - 7:49 PM
mgnt232
Joined Mar 16, '09
bump i have literally the same exact noise and only makes it when "under load". like the exact problem!Only seems to be the drivers side, havent noticed if its more going in reverse, its at any speed i think, just can here it more when at low speeds
I wish he posted if it was fixed by doing the bearings!
any new updates?
This post has been edited by mgnt232: Oct 8, 2013 - 7:50 PM
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
alllll balls. P2 approved!
post Oct 8, 2013 - 11:23 PM
schmooot
Joined Sep 29, '09
QUOTE (mgnt232 @ Oct 8, 2013 - 5:49 PM) *
any new updates?
Oh sorry, thought I had updated this. I forgot to torque the wheel nuts....I know it was a rookie mistake and I felt like/still feel like an idiot. I had put the wheels on just so I could relocate it in the shop during the winter and promptly forgot all about it. It was the aluminum spacers making the noise.
Don't judge me
Challenge Accepted
post Oct 9, 2013 - 2:08 PM
azian_advanced
Joined Apr 18, '05
From Calgary
Lesson learned I guess. Gotta be careful with that because I was involved in an accident going 100 km/h and all of a sudden the front left wheel came off. I was around 10 years old coming home from a camping trip and my mom was able to safely steer the van to the shoulder. We were lucky the van didn't flip.
post Oct 9, 2013 - 4:11 PM
mgnt232
Joined Mar 16, '09
oh well crap lol, I guess Ill check the tightness of the bolt tomorrow. Drove 14 hours back from new york would been pissed if the wheel fell off haha.
thanks ill keep it updated
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
Lo-Fi Version Time is now: August 9th, 2026 - 1:58 PM
