> Can anyone identify this piece?
post May 22, 2011 - 1:00 PM
torqu33bo1
Joined Aug 4, '10
From Stanhope, NJ
I can't figure out what this piece is and it just fell off.
post May 22, 2011 - 1:14 PM
torqu33bo1
Joined Aug 4, '10
From Stanhope, NJ
https://picasaweb.google.com/lh/photo/n6Bcu...feat=directlink
post May 22, 2011 - 2:50 PM
Neon90424
Joined Jan 19, '11
Thats the Flux Capacitor...
nah j.k seems to be part of the radiator system maybe temp sensor?
post May 22, 2011 - 4:02 PM
PolliS_5S-FE
Joined Aug 29, '08
From Auckland, New Zealand
lol mine has done that too. its a vacuum line i think?
post May 22, 2011 - 6:01 PM
mkernz22
Joined May 10, '10
From MA
its a vac line, put the hoses back on and zip tie them down
post May 22, 2011 - 7:35 PM
D-Man
Joined Jan 18, '08
From Houston
Is that the one with the single wire? If so it's the coolant temp sensor. on some models there is one with a hose that determines water presure/amount; i cant see from the pic.
Damn D-Man - most impressive.
post May 22, 2011 - 8:46 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
temp sensor. that sensor reads what you see on your gauge cluster.
God made man....
Everything else...
Made in China
post May 23, 2011 - 3:42 PM
torqu33bo1
Joined Aug 4, '10
From Stanhope, NJ
QUOTE (Neon90424 @ May 22, 2011 - 2:50 PM) *
Thats too funny!
Thank you all very much!
post May 23, 2011 - 4:03 PM
torqu33bo1
Joined Aug 4, '10
From Stanhope, NJ
Does anyone know what the top blue-ish green thing is. I looking it up and the coolant temp sensor is what it connects to.
post May 23, 2011 - 7:11 PM
mkernz22
Joined May 10, '10
From MA
the coolant temp sensor is in the radiator. that's a vac line, trust me, i just did an engine swap not that long ago and I had to hook everything back up. coolant, vac, and wiring because i completely pulled the engine
post May 28, 2011 - 2:08 AM
nics
Joined Feb 15, '08
From Royal Oak, MI
QUOTE (mkernz22 @ May 23, 2011 - 5:11 PM) *
there is another coolant temp sensor in the radiator. that is the ECT sensor for the fans to turn on or off.
God made man....
Everything else...
Made in China
post May 28, 2011 - 11:52 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
the circled part is a TVV for emissions I believe, TVV stands for thermal vacuum valve.
post May 31, 2011 - 6:15 PM
csscza
Joined Apr 28, '10
From Ft Worth
its also called bi metallic valve. I broke mine during head swap there pricey to but not having one wiil cost on milage
post Jun 1, 2011 - 3:48 AM
xIIscrapsIIx
Joined Mar 4, '09
From Ohio
Looks like no time travel for you...
Scraps
post Jun 1, 2011 - 4:20 AM
delusionz
Joined Feb 11, '08
QUOTE (nics @ May 28, 2011 - 7:08 PM) *
I have no idea what it is, but it certainly isnt that.
the thermo switch is in the bottom of the radiator, stick your hand down there and search for an electrical plug and unplug it, notice your fans will be constantly on.
its an electrical plug thats plugged into a bung shaped thing thats screwed in, thats the thermo switch and thats at the bottom of the radiator
when facing the front of the car it will be just to the right of the drain bung and outlet hose
Mike W
269awhp / 273ft-lbs
post Jun 1, 2011 - 5:07 AM
nics
Joined Feb 15, '08
From Royal Oak, MI
QUOTE (delusionz @ Jun 1, 2011 - 2:20 AM) *
yeah thats what it is. ECT switch. that is what i just said. it turn on and off the fan.
God made man....
Everything else...
Made in China
post Jun 1, 2011 - 5:45 AM
delusionz
Joined Feb 11, '08
Ok fair enough.
Well mine's here http://www.toyodiy.com/parts/p_J_1996_TOYO...3.html?hl=89428
SW Temperature in the bottom of the radiator.
On the back of my water outlet is the temperature sensor.
Wait.. what you showed is in the bottom of the radiator too, are you saying that plug ended up all the way up there? Bizarre.
Mike W
269awhp / 273ft-lbs
post Jun 1, 2011 - 2:26 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
QUOTE (delusionz @ Jun 1, 2011 - 3:45 AM) *
Ok fair enough.
the sensor on the back of the water outlet is for the temp gauge. the one that OP circled on the picture.
edit: can see your pix or the diagram in toyodiy
This post has been edited by nics: Jun 1, 2011 - 2:27 PM
God made man....
Everything else...
Made in China
Lo-Fi Version Time is now: June 21st, 2026 - 11:02 AM
