May 23, 2011 - 8:07 PM
Enthusiast Joined Mar 20, '11 From Jacksonville Fl Currently Offline Reputation: 0 (0%) |
OK so my 5sfe is leaking oil about a quart every oil change. Its coming the behind the timing belt cover. Im pretty sure its not the oil pan cause i checked it when i did the clutch. But i have most of the leak on the back side of the engine and around the timing cover. Ive read that it could be the oil pump seal or crank seal any thoughts? Powersteering is full.
dctacoma OIL LEAK May 23, 2011 - 8:07 PM
trdproven cam seal
could be a section of the corner valve co... May 24, 2011 - 4:01 AM
czwalga Oil pump seal. The seal is absolutely garbage. C... May 24, 2011 - 9:59 AM
StylnPlane QUOTE (dctacoma @ May 23, 2011 - 9:0... May 24, 2011 - 11:03 AM
rave2n Man I have to put in a quart once a week.
I have ... May 24, 2011 - 11:37 AM
StylnPlane QUOTE (rave2n @ May 24, 2011 - 11:37... May 24, 2011 - 11:51 AM
rave2n QUOTE (StylnPlane @ May 24, 2011 - 11... May 24, 2011 - 1:59 PM
chacha please post pics to show working progress as i als... May 24, 2011 - 2:55 PM
StylnPlane Da*n 2.2`s... May 24, 2011 - 6:44 PM
Smaay yep its the seal that goes around the post that th... May 25, 2011 - 9:10 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 27th, 2026 - 8:23 PM |
