May 26, 2011 - 9:32 PM
Enthusiast Joined Mar 20, '11 From Jacksonville Fl Currently Offline Reputation: 0 (0%) |
So im doing my timing belt this weekend and oil pump oring. Any advice on keeping pulleys from moving once the belt is off. And if its not to much trouble could someone describe one more time how to set the timing and keep it set the entire time while the belts off. Thanks
dctacoma Timing Belt Advice May 26, 2011 - 9:32 PM
Smaay just set the timing to TDC and make a note of wher... May 27, 2011 - 1:02 AM
dctacoma Ok thanks alot May 27, 2011 - 7:14 AM
czwalga What he said, although I'd recommend getting s... May 27, 2011 - 8:22 AM
dctacoma When you set the crank at tdc, should the cam shaf... May 27, 2011 - 9:09 AM
czwalga QUOTE (dctacoma @ May 27, 2011 - 10... May 27, 2011 - 9:27 AM
lagos Use a white paint pen (or white out, or something ... May 27, 2011 - 11:31 AM
ST205WRC there is also tools like this that can help keep t... May 27, 2011 - 11:54 AM
dctacoma OK i noticed some oil around the distributor has a... May 27, 2011 - 5:45 PM
Spider77 Wow, 32 bucks when a paint pen will do just fine..... May 27, 2011 - 5:45 PM
dctacoma So i got the timing belt on and what i thought was... May 28, 2011 - 6:03 PM
Spider77 As far as the crank goes there should be an alignm... May 28, 2011 - 6:54 PM
dctacoma I think i got my belt 1 or 2 teeth off. I put the ... May 29, 2011 - 2:46 PM
Spider77 i replied to your other thread.... May 29, 2011 - 5:50 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 29th, 2026 - 2:47 PM |
