May 28, 2011 - 10:00 AM
Enthusiast Joined Feb 3, '11 From jamaica Currently Offline Reputation: 0 (0%) |
i was just movin my turbo intake pipe to higher grounds because its rainy season in ja. i noticed i have no shaft play but there is some oil in front housen. is that a result of a ebay turbo
May 28, 2011 - 11:14 AM
Enthusiast ![]() ![]() Joined Jan 3, '06 From The Netherlands Currently Offline Reputation: 6 (100%) |
No, that's normal. If you don't want this to occur, you need to place an oil catch can.
-------------------- JDM ST205
May 29, 2011 - 4:58 AM
May 29, 2011 - 5:30 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
show us a picture of your engine bay, we have no idea what setup you're running, is it even 3s-gte?
-------------------- Mike W
May 30, 2011 - 9:52 PM
[quote name='delusionz' post='918465' date='May 29, 2011 - 5:30 AM']show us a picture of your engine bay, we have no idea what setup you're running, is it even 3s-gte?http://i1112.photobucket.com/albums/k498/gt38/IMG00325-20110528-0648.jpg
This post has been edited by gtprominient: May 30, 2011 - 10:49 PM |
May 30, 2011 - 10:52 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) |
![]() fixed -------------------- |
May 30, 2011 - 11:27 PM
oil in the housing is not normal. the seals in the turbo might be going out
May 31, 2011 - 1:18 AM
yeah, you dont have an oil breather in your intake so it can only be oil weeping from the seals inside the turbo
Jun 1, 2011 - 9:52 AM
yep thats what happened with my CT20B...oil outside the mouth dead seals
Jun 9, 2011 - 4:38 PM
Enthusiast ![]() Joined Oct 20, '08 From Lima,Peru Currently Offline Reputation: 0 (0%) |
will the realief valve work as the oil breather?
Jun 11, 2011 - 12:51 PM
NO
Buy an oil catch can they arent very expensive, If you block the crank case vapors you'll learn what a smoke screen looks like -------------------- |
| Lo-Fi Version | Time is now: July 29th, 2026 - 7:15 AM |
